Discuss
washer not running
 in
Washer Repair
My washer originally was not spinning. After consulting with a on line tech we decided it could be a door
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer not running
  #1 (permalink)
Old 09-03-2011, 05:20 PM
Junior Member
ajm1979 is on a distinguished road
Default washer not running
Model Number: 417.44042400   Brand: Sears   Age: 5 - 10 years
My washer originally was not spinning. After consulting with a on line tech we decided it could be a door latch switch or a timer. So being one that wanted to pursue it more I seen a test that someone did that by-passed the door switch. That was a problem....after trying that it tripped a breaker in the house. After that I ordered a timer and door switch. Replaced those both and still nothing. Next I thought it might be a speed control board and ordered one of those and replaced that, still nothing. I did a voltage test to the wiring harness that supplies the timer and one lead gets 120 volts. So I figure I am getting power at least. So being i am getting no sign of anything working I am wondering if it is now a control board? I have ohm tested the motor and that checks good. All i have left is the water pump and the control board. Any thoughts ? Thanks
Ads By Google
Related Models
Kenmore 417.59012890  GAS DRYER
Kenmore 417.69042990  KENMORE DRYER
Kenmore 417.69042991  DRYER
Kenmore 417.69052990  DRYER
Kenmore 417.69052991  ELECTRIC DRYER
Kenmore 417.79042990  DRYER
Kenmore 417.79042991  DRYER
Kenmore 417.79052990  DRYER
Kenmore 417.79052991  DRYER
Kenmore 417.80032990  DRYER
Kenmore 417.80042990  DRYER
Kenmore 417.80042991  DRYER
Kenmore 417.80052990  DRYER
Kenmore 417.80052991  DRYER
Kenmore 417.80142000  DRYER
Kenmore 417.81042000  DRYER
Kenmore 417.81042001  DRYER
Kenmore 417.81052000  ELECTRIC DRYER
Kenmore 417.81052001  DRYER
Kenmore 417.81142000  DRYER
Kenmore 417.81142001  DRYER
Kenmore 417.82042100  DRYER
Kenmore 417.82042101  DRYER
Kenmore 417.82042102  SEARS/DRYER
Kenmore 417.82052100  DRYER
Kenmore 417.82052101  DRYER
Kenmore 417.82052102  DRYER
Kenmore 417.82052103  SEARS/ELECTRIC DRYER
Kenmore 417.82142100  DRYER
Kenmore 417.82142101  DRYER
Kenmore 417.82142102  SEARS/ELECTRIC DRYER
Kenmore 417.83042200  SEARS/DRYER
Kenmore 417.83042201  SEARS/ELECTRIC DRYER
Kenmore 417.83052200  SEARS/DRYER
Kenmore 417.83052201  SEARS/DRYER
Kenmore 417.83142200  SEARS/DRYER
Kenmore 417.83142201  SEARS/ELECTRIC DRYER
Kenmore 417.88988100  ELECTRIC DRYER
Kenmore 417.88988800  ELECTRIC DRYER
Kenmore 417.88989100  GAS DRYER
Kenmore 417.88989800  GAS DRYER
Kenmore 417.89090100  WASHER DRYER COMBINATION
Kenmore 417.89090110  COMBINATION WASHER-DRYER
Kenmore 417.89090200  WASHER DRYER COMBINATION
Kenmore 417.89090210  COMBINATION WASHER-DRYER
Kenmore 417.89090400  WASHER DRYER COMBINATION
Kenmore 417.89090410  COMBINATION WASHER-DRYER
Kenmore 417.89090600  WASHER DRYER COMBINATION
Kenmore 417.89090610  COMBINATION WASHER-DRYER
Kenmore 417.89090800  WASHER DRYER COMBINATION
Kenmore 417.89090810  COMBINATION WASHER-DRYER
Kenmore 417.90032990  DRYER
Kenmore 417.90042990  DRYER
Kenmore 417.90042991  DRYER
Kenmore 417.90052990  DRYER
Kenmore 417.90052991  DRYER
Kenmore 417.90142000  DRYER
Kenmore 417.90802990  LAUNDRY CENTER
Kenmore 417.90802991  LAUNDRY CENTER
Kenmore 417.90802992  LAUNDRY CENTER
Kenmore 417.90807990  LAUNDRY CENTER
Kenmore 417.90812990  LAUNDRY CENTER
Kenmore 417.90812991  LAUNDRY CENTER
Kenmore 417.90812992  LAUNDRY CENTER
Kenmore 417.90814000  LAUNDRY CENTER
Kenmore 417.90814001  LAUNDRY CENTER
Kenmore 417.90814002  LAUNDRY CENTER
Kenmore 417.90817990  LAUNDRY CENTER
Kenmore 417.90862990  LAUNDRY CENTER
Kenmore 417.90862991  LAUNDRY CENTER
Kenmore 417.90862992  LAUNDRY CENTER
Kenmore 417.90872990  LAUNDRY CENTER
Kenmore 417.90872991  LAUNDRY CENTER
Kenmore 417.90872992  LAUNDRY CENTER
Kenmore 417.91042000  DRYER
Kenmore 417.91042001  DRYER
Kenmore 417.91052000  GAS DRYER
Kenmore 417.91052001  DRYER
Kenmore 417.91142000  DRYER
Kenmore 417.91142001  DRYER
Kenmore 417.91702000  LAUNDRY CENTER
Kenmore 417.91702001  LAUNDRY CENTER
Kenmore 417.92042100  DRYER
Kenmore 417.92042101  DRYER
Kenmore 417.92042102  SEARS/GAS DRYER
Kenmore 417.92052101  DRYER
Kenmore 417.92052102  DRYER
Kenmore 417.92052103  SEARS/GAS DRYER
Kenmore 417.92142100  DRYER
Kenmore 417.92142101  DRYER
Kenmore 417.92142102  SEARS/GAS DRYER
Kenmore 417.92702200  LAUNDRY CENTER
Kenmore 417.93042200  SEARS/DRYER
Kenmore 417.93042201  SEARS/DRYER
Kenmore 417.93052200  SEARS/DRYER
Kenmore 417.93052201  SEARS/DRYER
Kenmore 417.93142200  SEARS/DRYER
Kenmore 417.93142201  SEARS/DRYER
Kenmore 417.93702200  LAUNDRY CENTER
Kenmore 417.93802200  LAUNDRY CENTER
Frigidaire 41739012890 Frg(v0) / Washer
Frigidaire 41739012891
Frigidaire 41739022890 Frg(v0) / Washer
Frigidaire 41739022891 Frg/washer
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Kenmore 41789190800 COMBINATION WASHER/DRYER
Kenmore 41789190810 COMBINATION WASHER/DRYER
Kenmore 41789190820 COMBINATION WASHER/DRYER
Kenmore 41789195100 COMBINATION WASHER/DRYER
  #2 (permalink)
Old 09-04-2011, 01:51 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Well my first hope is that you bought the parts from this site, since you can return them if they did not fix the problem.
It sounds like the control unit since you have replaced everything else, but check out things with this service manual.
http://www.emaservicetips.com/pdfs/3...ionWashers.pdf
__________________
  #3 (permalink)
Old 09-05-2011, 02:35 PM
Junior Member
Default
Thanks for your reply. The manual you sent was more helpful than the tech sheets that were inside the washer. For my problem "washer not operating" it gives me two options when the timer knob is pulled out. If the door latch lamp does not glow to test the lead to the door switch. I do not get any of the lights that glow so i tested the one lead that goes from the door switch that is inline with the reed switch. I get 120volts. So by this test if I read it correctly tells me i have a faulty reed switch. If it read 0 it would have been my timer. I located the reed switch and wondered if there was another test to confirm my results on the leads to the reed switch itself? This has two wires with about a 6" lead to a plastic connector plug. Any thoughts?
So I am wondering if I should order both the reed switch and the control board to be sure?? Thanks!
  #4 (permalink)
Old 09-05-2011, 05:47 PM
Senior Expert
APP Volunteer
Default
It sounds like your control board is ok if it is sending 120v to the switch. You can order both parts to save time and if you do not need one you can return it if you order from this site.
__________________
  #5 (permalink)
Old 09-05-2011, 06:03 PM
Junior Member
Default
Thank you, I will order both parts just to save time as you said. Yes, I have ordered all my parts from this site. It is great to be able to order more than one knowing you can return it if you do not need the part.
Hoping this part does the trick.
  #6 (permalink)
Old 09-07-2011, 06:20 PM
Junior Member
Default
I wanted to follow up with my fix. The part that was causing the washer not to operate at all was the reed switch. If you recall this ended up being the part that I must have damaged when i tried jumping the door lock switch.
After I replaced the reed switch I was back to where I started when my washer would not go into spin mode. After I tried a new door lock switch, that did not work. Next I tried the new timer, still did not allow it to spin. Next was the speed control assembly board. It is true, the third time is a charm. In my case the speed control assembly board was the reason it was not going into spin mode. Not to be confused with the control board. I thank you for your help and the ability to be able to purchase parts and return the ones I do not need. I am about to start the return process now.
Thanks. Hope this is able to help someone else.
  #7 (permalink)
Old 09-07-2011, 07:15 PM
Senior Expert
APP Volunteer
Default
Well great, glad you got it running. The speed control board is the usualy problem with spin issues.
Thanks for the update, that is very helpful.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer over running brake PETAMAN Washer Repair 1 02-28-2011 04:01 AM
Washer Not Running ryana Dishwasher Repair 1 11-28-2009 03:27 AM
Washer running but.... Jennifer Kristiansen Washer Repair 1 06-24-2009 01:15 PM
Washer keeps running water 2bobby Washer Repair 3 01-15-2009 06:23 AM
Washer just keeps running!!!!! kathiep Washer Repair 1 11-15-2008 05:35 PM
