Discuss
washer only works on spin
 in
Washer Repair
I am in the middle of trying to diagnose a whirlpool estate washer for a friend. It worked fine and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer only works on spin
  #1 (permalink)
Old 09-03-2011, 11:46 AM
hmm hmm is offline
Junior Member
hmm is on a distinguished road
Default washer only works on spin
Model Number: estate taws800jq0   Brand: Whirlpool   Age: More than 10 years
I am in the middle of trying to diagnose a whirlpool estate washer for a friend. It worked fine and without warning, would not work when a new load was tried. The only setting that seems to work is spin. I have checked water flow, power from the outlet filter screens and all are fine. The lid switch was replaced about 2 months ago and the unit does work in the one setting. I checked the water level switch for tube clogging and checked for resistance and got zero ohms. I have checked the inlet valve and seem to get a reading of 1,150 plus ohms. This seems high but would this cause all other functions besides spin to cease? If so, can I "trick" the washer to see if the other functions engage to verify that the timer is not faulty? Where do I go from here?
Related Models
Amana ESU12HW FREEZER- VERTICAL
Amana ESU12JW FREEZER- VERTICAL
Amana ESU13 FREEZER- VERTICAL
Amana ESU13-A FREEZER- VERTICAL
Amana ESU13-AG FREEZER- VERTICAL
Amana ESU13-C FREEZER- VERTICAL
Amana ESU13-L FREEZER- VERTICAL
Amana ESU13B FREEZER- VERTICAL
Amana ESU13B-A FREEZER- VERTICAL
Amana ESU13B-C FREEZER- VERTICAL
Amana ESU13B-G FREEZER- VERTICAL
Amana ESU13B-L FREEZER- VERTICAL
Amana ESU13C FREEZER- VERTICAL
Amana ESU13C-A FREEZER- VERTICAL
Amana ESU13C-C FREEZER- VERTICAL
Amana ESU13C-G FREEZER- VERTICAL
Amana ESU13CL FREEZER- VERTICAL
Amana ESU13D FREEZER- VERTICAL
Amana ESU13DW FREEZER- VERTICAL
Amana ESU15 FREEZER- VERTICAL
Amana ESU15-A FREEZER- VERTICAL
Amana ESU15-AG FREEZER- VERTICAL
Amana ESU15-C FREEZER- VERTICAL
Amana ESU15-L FREEZER- VERTICAL
Amana ESU15B FREEZER- VERTICAL
Amana ESU15B-A FREEZER- VERTICAL
Amana ESU15B-C FREEZER- VERTICAL
Amana ESU15B-G FREEZER- VERTICAL
Amana ESU15B-L FREEZER- VERTICAL
Amana ESU15C FREEZER- VERTICAL
Amana ESU15C-A FREEZER- VERTICAL
Amana ESU15C-C FREEZER- VERTICAL
Amana ESU15C-G FREEZER- VERTICAL
Amana ESU15CL FREEZER- VERTICAL
Amana ESU15D FREEZER- VERTICAL
Amana ESU15DW FREEZER- VERTICAL
Amana ESU15HW FREEZER- VERTICAL
Amana ESU15JW FREEZER- VERTICAL
Amana ESU17 FREEZER- VERTICAL
Amana ESU17-A FREEZER- VERTICAL
Amana ESU17-AG FREEZER- VERTICAL
Amana ESU17-C FREEZER- VERTICAL
Amana ESU17-L FREEZER- VERTICAL
Amana ESU17B FREEZER- VERTICAL
Amana ESU17B-A FREEZER- VERTICAL
Amana ESU17B-C FREEZER- VERTICAL
Amana ESU17B-G FREEZER- VERTICAL
Amana ESU17B-L FREEZER- VERTICAL
Amana ESU17C FREEZER- VERTICAL
Amana ESU17C-A FREEZER- VERTICAL
Amana ESU17C-C FREEZER- VERTICAL
Amana ESU17C-G FREEZER- VERTICAL
Amana ESU17CL FREEZER- VERTICAL
Amana ESU17D FREEZER- VERTICAL
Amana ESU17DW FREEZER- VERTICAL
Amana ESU17HW FREEZER- VERTICAL
Amana ESU17JW FREEZER- VERTICAL
Amana ESU20HW FREEZER- VERTICAL
Amana ESU20JW FREEZER- VERTICAL
Amana ESU513 FREEZER- VERTICAL
Amana ESU513-A FREEZER- VERTICAL
Amana ESU513-AG FREEZER- VERTICAL
Amana ESU513-C FREEZER- VERTICAL
Amana ESU513-L FREEZER- VERTICAL
Amana ESU515 FREEZER- VERTICAL
Amana ESU515-A FREEZER- VERTICAL
Amana ESU515-AG FREEZER- VERTICAL
Amana ESU515-C FREEZER- VERTICAL
Amana ESU515-L FREEZER- VERTICAL
Amana ESU517 FREEZER- VERTICAL
Amana ESU517-A FREEZER- VERTICAL
Amana ESU517-AG FREEZER- VERTICAL
Amana ESU517-C FREEZER- VERTICAL
Amana ESU517-L FREEZER- VERTICAL
Amana ESUF14 FREEZER- VERTICAL
Amana ESUF14-A FREEZER- VERTICAL
Amana ESUF14-AG FREEZER- VERTICAL
Amana ESUF14-C FREEZER- VERTICAL
Amana ESUF14-L FREEZER- VERTICAL
Amana ESUF14B FREEZER- VERTICAL
Amana ESUF14B-A FREEZER- VERTICAL
Amana ESUF14B-AG FREEZER- VERTICAL
Amana ESUF14B-C FREEZER- VERTICAL
Amana ESUF14B-L FREEZER- VERTICAL
Amana ESUF14C FREEZER- VERTICAL
Amana ESUF14C-A FREEZER- VERTICAL
Amana ESUF14C-C FREEZER- VERTICAL
Amana ESUF14C-G FREEZER- VERTICAL
Amana ESUF14C-L FREEZER- VERTICAL
Amana ESUF15HW FREEZER- VERTICAL
Amana ESUF15JW FREEZER- VERTICAL
Amana ESUF16 FREEZER- VERTICAL
Amana ESUF16-A FREEZER- VERTICAL
Amana ESUF16-AG FREEZER- VERTICAL
Amana ESUF16-C FREEZER- VERTICAL
Amana ESUF16-L FREEZER- VERTICAL
Amana ESUF16B FREEZER- VERTICAL
Amana ESUF16B-A FREEZER- VERTICAL
Amana ESUF16B-AG FREEZER- VERTICAL
Amana ESUF16B-C FREEZER- VERTICAL
Amana ESUF16B-L FREEZER- VERTICAL
Amana ESUF16C FREEZER- VERTICAL
Amana ESUF16C-A FREEZER- VERTICAL
  #2 (permalink)
Old 09-04-2011, 01:37 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Here is a couple of things you can do.
Blow into the water level switch tube and see if you can hear the switch "click". If so, it is probably ok. Then check to see if 110-20 v is going to the valve assembly when the machine is supposed to be filling. If not, the timer is probably at fault. If the valves are getting power, the valve assembly is at fault.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Washer will not spin, otherwise works okay cw3120 Washer Repair 0 12-04-2010 10:37 AM
whirlpool washer works but does'nt spin mike f Washer Repair 2 02-25-2010 03:58 AM
Washer works fine until spin cycle biggfellael Washer Repair 0 04-13-2009 05:27 AM
Washer works fine until spin cycle biggfellael Washer Repair 0 04-13-2009 05:13 AM
washer works but does't spin 0034 Washer Repair 2 01-02-2009 08:07 PM
