AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmor Washer Wont Spin/agitate New Controllor Installed
i HAD A POWER SURGE AND BLEW MY CONTROLLOR BOARD OUT, it wouldent even light up, i installed a new board assembly and now it will fill with water , but will not aggitate , or spin in any setting , but will drain .the drum spins free, this machine wash working fine before the power surge, I checked the lid switch it is working fine?>? help
You may have blown the inverter in the power problem, but hopefully you didn't and all it needs is to be reset. Try resetting it using these instructions HydroWave GE Washer Repair Guideif that does not work see if you have an error code.
Washer Repair
