| » Frigidaire Front Load Washer Won't Spin |
Model Number: FWT449gfs1 Brand: Frigidaire Age: 5 - 10 years
Problem: Will drain, won't spin Question: Repairman told me for $350+ - he would fix washer and replace broken control board and motor.
I replaced both the speed control board and the motor. First, I replaced the speed board and was able to run about 4 loads. Then the machine would get to the final or fast spin cycle but would never kick into the spin. So I went ahead and replaced the motor but no change. The tech sheet was missing from my washer. I have a multimeter to test but honestly have no idea how to use it. All of the service manuals that I have seen or been provided appear to be from 2002 or 2003 but i think my washer was manufactured in 1998 if that makes a difference. Since I have invested so much already I am hoping that I can still fix it without having someone look at it. But at a loss as to where to go from here. Any help is most appreciated. Thanks. Ads By Google Related Models |
Wire Connectors - on the speed control board that was replaced, correct?
Yes, it ran for approx 4 loads before it stopped spinning. It runs through all other cycles fine. Thanks in advance. Last edited by bbemis : 11-28-2007 at 07:48 AM. Reason: added content |
| Display Modes | |
| Frigidaire front load washer will not spin | Merlis | Washer Repair | 14 | 12-06-2012 04:08 PM |
| frigidaire front load washer will not spin only tumbles | FILTTY | Washer Repair | 1 | 02-14-2010 06:53 AM |
| frigidaire front load washer will not go into final spin | cubbie23 | Washer Repair | 2 | 02-12-2010 12:40 PM |
| Front load Frigidaire won't spin at all | Gangster | Washer Repair | 2 | 12-13-2008 07:33 AM |
| Frigidaire front load washer won't spin | jociadam | Washer Repair | 1 | 07-03-2008 06:52 AM |
