solve for "nd" error code
Symptoms: will wash on any cycle; at "Rinse" drain pump will operate for 2-3 seconds; "Spin" will not engage. If I go straight to "Rinse & Spin" nothing happens and timer will operate. If I go to "Spin" only, drain [i]may[i] work for 2-3 secs, then it fails to finish draining. Occasionally, spin cycle will begin after several minutes delay, or after "Pause" and re-start with opening door.
Question: Is this more likely to be the Pump-Drain, or more likely the controller? The occasional (though incomplete) operation of the pump has me confused. |
I am having the same problem with my Samsung WF316LAS/XXA. I have replaced the drain pump and it still doesn't work. Does anyone know what could be wrong?
| All times are GMT -7. The time now is 09:20 PM. |
