The rear tub bearing is shot. I have removed the pulley for the spinner and the retaining ring for the bearing. the ball bearing fell out or I remove some of them. How do I get the rest of the bearing out... the outer edge won't budge and it looks like a portion of the inner part of the bearing is stuck to the spinner
Go to the forum announcement section and search for my article "Replacing Neptune bearings", a rather time consuming job.
