Discuss
washer/water shuts off when hits all rinse cycles
 in
Washer Repair
when the timer hits the rinse cycles, the water cuts off. We ordered a timer, but that didn't fix the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer/water shuts off when hits all rinse cycles
  #1 (permalink)
Old 11-27-2007, 04:30 PM
Junior Member
c4cdlm is on a distinguished road
Unhappy washer/water shuts off when hits all rinse cycles
Model Number: 110.26934690   Brand: Kenmore   Age: 5 - 10 years
when the timer hits the rinse cycles, the water cuts off. We ordered a timer, but that didn't fix the problem. Could it be the water dispensing valve. Water flows in the wash cycle.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 11-27-2007, 05:57 PM
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
Does this washer have a water selector switch [cold,cold,cold,warm cold,hot etc.]if it does, check to see if it is working ok and make sure the washer fill hoses are not REVERSED on taps. this can cause the problem.
__________________
  #3 (permalink)
Old 11-28-2007, 06:40 AM
Junior Member
Default
hoses on are correct taps, although this problem didn't start until I put new hoses on. Water selecter switch is working correctly.
  #4 (permalink)
Old 11-28-2007, 12:53 PM
Senior Expert
APP Volunteer
Default
make sure the both taps are open, then check to see if the cold water hose is on the right part of the mixing valve on the back of the washer,most of the time the washer valve is marked hot and cold. Cold on top and hot on bottom.
__________________
  #5 (permalink)
Old 11-28-2007, 04:33 PM
Junior Member
Default
checked both connection on washer and they are hooked up correctly, hot to red and cold to green. Any other suggestions? Now when in wash cycle, water stops occasionally.
  #6 (permalink)
Old 12-16-2008, 04:48 PM
Junior Member
Rnance is on a distinguished road
Thumbs up Lid Switch
We just had our Whirlpool - Estate Brand washer doing the exact same thing. We ended up having a repair man come over and it turned out to be the lid switch needed replacing. Unfortunatly this is our second lid switch costing us a little under 100.00 per pop, but now that I've seen it done I'm sure I could order a replacement part from this site and switch it out myself.
  #7 (permalink)
Old 12-17-2008, 03:42 PM
Junior Member
Default
ours turned out to be steel hoses were on backwards, and wouldn't let the water in.
  #8 (permalink)
Old 12-17-2008, 03:46 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Gotta watch those anti flood hoses with the check valves in them
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Esate Whirlpool Washer-timer stops once it hits rinse and i manually move to spin joana83 Washer Repair 3 05-17-2009 10:05 AM
Washer stops at rinse cycles Aubriella Washer Repair 4 12-06-2008 10:28 AM
No water in on rinse cycles Sulley Washer Repair 2 12-02-2008 03:22 AM
My Washer Will Not Spin Out Water Or Rinse. FootballMOM75 Washer Repair 1 08-25-2008 07:34 PM
Amana Washer, clothes still soapy after two rinse cycles amyandwade Washer Repair 0 03-30-2008 08:16 AM
