Discuss
No Cold Water in Washing Machine
 in
Washer Repair
When filling the washing machine with water, only the hot water comes out, but not the cold water, even though
Appliance Repair Forum > Appliance Repair Help > Washer Repair » No Cold Water in Washing Machine
  #1 (permalink)
Old 04-06-2009, 03:06 PM
Junior Member
Biskiii is on a distinguished road
Default No Cold Water in Washing Machine
Brand: -brand-   Age: 5 - 10 years
When filling the washing machine with water, only the hot water comes out, but not the cold water, even though both taps are turned on.
What can I do?
  #2 (permalink)
Old 04-06-2009, 03:30 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Turn off the water
Remove the hose from the tap
Run water into a pail
Just to make sure you have water there.
Remove the hose from the machine.
Check both ends some sealing washers have filter screens built in.
If OK
Reattach the hose to the tap
Just to be sure that you do not have a collapsed hose.
Check the filter screen on the input side of the machines water valve.
If dirty clean it
Do not remove it. It is there to keep crud out of the machine.
Unplug the unit swap the wires from the cold valve to the hot valve and vise versa.
Plug the unit in
Give it a try
Now if you have cold water you know the valve is opening and there is a problem with the electrical. One side is not getting voltage.
If you do not get cold water the cold side of the valve is shot.
Just remember that you swapped the wires so you put them back on the correct valve when you replace it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water pump - Washing Machine bdsoper Washer Repair 3 02-09-2010 06:05 PM
Washing machine does not fill up with water Eddiedean Washer Repair 1 01-29-2010 11:14 AM
washing machine won't spin the water out it jgosch Washer Repair 0 05-09-2009 12:05 PM
My washing machine fills with water, but that's it pejza Washer Repair 2 07-12-2008 01:47 PM
My washing machine fills water, but that's it Cougy Washer Repair 4 07-01-2008 09:28 PM
