Discuss
washer starts to fill then stops
 in
Washer Repair
washer starts to fill then stops after about 15 seconds. the timer is good, the water level switch is good
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer starts to fill then stops
  #1 (permalink)
Old 08-30-2011, 02:15 PM
Junior Member
richie33 is on a distinguished road
Default washer starts to fill then stops
Brand: Kenmore   Age: 1 - 5 years
the timer is good, the water level switch is good , the hose is not pluged.
any sugestions
  #2 (permalink)
Old 08-31-2011, 07:40 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
When it stops check and see if 120v is getting to the water valve assembly. If it is, replace the assembly, if not probably need to replace timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer starts to fill then stops richie33 Dishwasher Repair 2 11-03-2011 09:32 PM
Starts to fill and then stops after 15 seconds becky123 Washer Repair 1 08-01-2011 07:19 PM
Washer Starts Then Stops hider Washer Repair 1 07-19-2011 08:01 PM
Roper washer starts to fill and stops phish_phinder Washer Repair 6 01-17-2011 12:22 PM
Whirlpool Washer Starts Stops And Hums beverlyjean Washer Repair 1 06-02-2009 03:35 PM
