| » my washer doesn't spin or drain |
Model Number: kaws577eq0 Brand: Kitchen Aid Age: More than 10 years
Hi, my washer doesn't spin or drain, I don't know what to. I checked the outlet for power, it is ok because it goes on the washing cycle, the lid seems to be ok, so my guess is that it may be the pump or something else, can you help?
Thank you! Ads By Google Related Models |
The first and major failure suspect is the lid switch (#11 on the diagram). It is easy to test it. Open the control panel, unplug the lid switch wire plug and bypass it. Run the washer. If it does drain and spin then the lid switch has to be replaced.
- The part number for the lid switch is AP3100003 Here are the break down diagrams and Replacement parts for WHIRLPOOL KAWS577EQ0 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| GE Washer will not drain or spin | myzippo27 | Washer Repair | 6 | 04-12-2012 11:05 PM |
| washer won't drain and spin | caullfieldj | Washer Repair | 1 | 03-30-2009 04:39 PM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
| washer will not spin or drain | Martha Shelby | Washer Repair | 1 | 10-24-2007 03:59 AM |
| Washer won't drain or spin | carrol | Washer Repair | 2 | 08-20-2007 06:37 AM |
