Discuss
maytag neptune door lock
 in
Washer Repair
I was given this washer because they "couldn't get the door to work". It gives you an error code that
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag neptune door lock
  #1 (permalink)
Old 04-05-2009, 04:39 PM
Junior Member
another mom is on a distinguished road
Question maytag neptune door lock
Model Number: mah5500bww   Brand: Maytag   Age: 1 - 5 years
I was given this washer because they "couldn't get the door to work". It gives you an error code that the door is unlocked.
the rotating cam is in the locked position, keeping the door from closing. I can manually do the door lock test through the service mode. I can hear the switch working, but the cam stays in place. reminds me of a car door lock that was manuevered when the door was open. Does that make sense? washer works fine if something is put in front of the door to hold it shut. You just have to go through the service mode, lock and unlock the door, then set it, and it'll run. any ideas? Can the cam be rotated back, or do I need to buy another switch?
Rhonda
Ads By Google
Related Models
Maytag MAH5500BWW Washer - Horizontal Axis
Maytag MAH55FLBWQ Washer - Horizontal Axis
Maytag MAH55FLBWW Washer - Horizontal Axis
Maytag MAH6500AWQ Washer - Horizontal Axis
Maytag MAH6500AWW Washer - Horizontal Axis
Maytag MAH6700AWM Washer - Horizontal Axis
Maytag MAH6700AWW Washer - Horizontal Axis
Maytag MAH7500AWQ Washer - Horizontal Axis
Maytag MAH7500AWW Washer - Horizontal Axis
International MAH7550AAW Washer - Horizontal Axis
Maytag MAH7550AGW Washer - Horizontal Axis
International MAH7550AGW Washer - Horizontal Axis
Maytag MAH8700AWM Washer - Horizontal Axis
Maytag MAH8700AWW Washer - Horizontal Axis
Maytag MAH9700AWM Washer - Horizontal Axis
Maytag MAH9700AWQ Washer - Horizontal Axis
Maytag MAH9700AWW Washer - Horizontal Axis
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM Misc / Accessory
Maytag MAL1800AXQ Misc / Accessory
Maytag MAL1800AXW Misc / Accessory
Maytag MAL2000AXQ Misc / Accessory
Maytag MAL2000AXW Misc / Accessory
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL Washer - Top Loading
Maytag MAT10CSAAW Washer - Top Loading
Maytag MAT10CSAGL Washer - Top Loading
Maytag MAT10CSAGW Washer - Top Loading
Maytag MAT10CSBKL Washer - Top Loading
Maytag MAT10CSEGL Washer - Top Loading
Maytag MAT10CSEGW Washer - Top Loading
Maytag MAT10DAAAL Washer - Top Loading
Maytag MAT10DAAAW Washer - Top Loading
Maytag MAT10DAABL Washer - Top Loading
Maytag MAT10DAABW Washer - Top Loading
Maytag MAT10PDAAL Washer - Top Loading
Maytag MAT10PDAAW Washer - Top Loading
Maytag MAT10PDABL Washer - Top Loading
Maytag MAT10PDABW Washer - Top Loading
Maytag MAT10PDEGW Washer - Top Loading
Maytag MAT10PSAAL Washer - Top Loading
Maytag MAT10PSAAW Washer - Top Loading
Maytag MAT10PSAGL Washer - Top Loading
Maytag MAT10PSAGW Washer - Top Loading
Maytag MAT11CSBKL Washer - Top Loading
Maytag MAT11MNAAW Washer - Top Loading
Maytag MAT11MNAGW Washer - Top Loading
Maytag MAT11MNEGW Washer - Top Loading
Maytag MAT11PDAAL Washer - Top Loading
Maytag MAT11PDAAW Washer - Top Loading
Maytag MAT11PDABL Washer - Top Loading
Maytag MAT11PDABW Washer - Top Loading
Maytag MAT12CSAAL Washer - Top Loading
Maytag MAT12CSAAQ Washer - Top Loading
Maytag MAT12CSAAW Washer - Top Loading
Maytag MAT12CSAGW Washer - Top Loading
Maytag MAT12CSAKL Washer - Top Loading
Maytag MAT12CSAKQ Washer - Top Loading
Maytag MAT12CSDAQ Washer - Top Loading
Maytag MAT12CSDAW Washer - Top Loading
Maytag MAT12CSDGW Washer - Top Loading
Maytag MAT12CSEGW Washer - Top Loading
Maytag MAT12CSFWQ Washer - Top Loading
Maytag MAT12CSFWW Washer - Top Loading
Maytag MAT12PDAAL Washer - Top Loading
Maytag MAT12PDAAW Washer - Top Loading
Maytag MAT12PDABL Washer - Top Loading
Maytag MAT12PDABW Washer - Top Loading
Maytag MAT12PDAGW Washer - Top Loading
Maytag MAT12PDBAL Washer - Top Loading
Maytag MAT12PDBAQ Washer - Top Loading
Maytag MAT12PDBAW Washer - Top Loading
Maytag MAT12PDBBL Washer - Top Loading
Maytag MAT12PDBBQ Washer - Top Loading
Maytag MAT12PDBBW Washer - Top Loading
Maytag MAT12PDCBL Washer - Top Loading
Maytag MAT12PDCBQ Washer - Top Loading
Maytag MAT12PDCBW Washer - Top Loading
Maytag MAT12PDDAQ Washer - Top Loading
Maytag MAT12PDDAW Washer - Top Loading
Maytag MAT12PDDBW Washer - Top Loading
Maytag MAT12PDDGW Washer - Top Loading
Maytag MAT12PDEGW Washer - Top Loading
Maytag MAT12PDLAQ Washer - Top Loading
Maytag MAT12PDLAW Washer - Top Loading
Maytag MAT12PDLGW Washer - Top Loading
Maytag MAT12PDSAW Washer - Top Loading
Maytag MAT12PRAAW Washer - Top Loading
Maytag MAT12PRAEW Washer - Top Loading
Maytag MAT12PRBAW Washer - Top Loading
Maytag MAT12PRDAW Washer - Top Loading
Maytag MAT12PRSAW Washer - Top Loading
Maytag MAT12PSAAW Washer - Top Loading
Maytag MAT12PSAGW Washer - Top Loading
Maytag MAT12PSBAW Washer - Top Loading
Maytag MAT12PSDAW Washer - Top Loading
Maytag MAT12PSLWQ Washer - Top Loading
Maytag MAT12PSLWW Washer - Top Loading
Maytag MAT13MNAAW Washer - Top Loading
Maytag MAT13MNAGW Washer - Top Loading
Maytag MAT13MNDAW Washer - Top Loading
Maytag MAT13MNDGW Washer - Top Loading
Maytag MAT13MNEGW Washer - Top Loading
Maytag MAT13PDAAW Washer - Top Loading
Maytag MAT13PDBAW Washer - Top Loading
Maytag MAT13PNAEW Washer - Top Loading
Maytag MAT13PNDEW Washer - Top Loading
Maytag MAT13PRBWW Washer - Top Loading
Maytag MAT230CAAG Washer - Top Loading
Maytag MAT23PCAAC Washer - Top Loading
Maytag MAT23PCAAG Washer - Top Loading
Maytag MAT23PCAAL Washer - Top Loading
Maytag MAT23PCAAW Washer - Top Loading
Maytag MAT23PCABG Washer - Top Loading
Maytag MAT23PCABL Washer - Top Loading
Maytag MAT23PCABW Washer - Top Loading
Maytag MAT25CSAAG Washer - Top Loading
Maytag MAT25CSAAL Washer - Top Loading
Maytag MAT25CSAAW Washer - Top Loading
Maytag MAT25CSAGG Washer - Top Loading
  #2 (permalink)
Old 04-06-2009, 04:38 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Sounds like the switch is working since it passes diagnostics.
More like you have a mechanical latch problem.
Perhaps the following will help
http://www.servicematters.com/maytag...s/16010061.pdf
__________________
  #3 (permalink)
Old 04-06-2009, 06:51 AM
Junior Member
Default
well,I got brave, and looked to see which way the cam turned. I used a screwdriver and pushed it until it physically unlocked. It clicked so hard and loud, I was afraid I'd snapped it off, being plastic, but it seems to be working now. I figured if I actually broke the piece off, I'd have to replace the whole switch, but if I did nothing, it was going to have to be replaced, anyway. I didn't mind doing the diagnostic each time, but it was rather a pain! So, for the cost of a soap dispenser, which is weirdly missing,and a LOT of cleaning, I got a nice maytag neptune.
Now, if I could figure out what's wrong with my ge frontloader, I could bless someone else with a nice washer!
Thanks for sending me in the right direction!
Rhonda
  #4 (permalink)
Old 04-06-2009, 08:05 AM
Senior Expert
APP Volunteer
Default
On the GE problem, I would start a new thread of your own.
I did look up your previous post and saw that it was just added to another persons thread and the original problem was on a Frigidaire.
You may get a better response with your own thread.
Problem is that GE is a pain to get any info on but it is worth a try.
__________________
  #5 (permalink)
Old 04-06-2009, 11:58 AM
Junior Member
Default
thanks, I'll try that
Rhonda
  #6 (permalink)
Old 07-09-2009, 04:50 PM
Junior Member
tokmik is on a distinguished road
Default
Our experience professionals always start with these lock and safety basics, and move forward from there to create safe, comprehensive lock solutions tailored to meet a variety of home security needs.Your home and your safety is important to us phoenix locksmith.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
unlock door on a Maytag neptune washer TimN Washer Repair 1 02-08-2010 12:26 PM
Maytag Washer Door Lock Won't Unlock Alan Lieberman Washer Repair 2 07-24-2009 04:02 AM
Door Lock Switch Neptune Robertydebbie Washer Repair 1 06-15-2009 06:04 PM
Maytag door lock spin cycle Lyon Washer Repair 0 08-08-2008 08:15 AM
Door lock Maytag elect. range jilsan Oven Repair (including Ranges and Cooktops) 0 01-26-2008 06:07 AM
