| » Agitates only small loads |
Model Number: WTW5530SQ0 Brand: Whirlpool Age: 1 - 5 years
My Whirlpool washer will only agitate for small loads. Large load of towels, for example, it won't agitate (or spin). Drains without issue. Thanks for any help you can provide.
Quote:
For the agitation issye, remove the agitator and check the splines on the inside of the agitator bottom Part number: AP2906554 and the transmission output shaft, the splines could be worn down and slipping on the shaft, with a large or heavy load, otherwise you'll need a new transmission/gearcase. As for the poor spin issue, you most likely have a slipping clutch assembly Part number: AP3094537 or a damaged motor coupler Part number: AP3963893 Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Having to dry loads twice | croberson | Dryer Repair | 1 | 02-08-2011 03:12 AM |
| Whirlpool LA7680XMW0 won't agitate except small loads | steven1955 | Washer Repair | 3 | 12-21-2010 01:47 PM |
| only fills small loads for water | jeff n | Washer Repair | 1 | 11-16-2010 07:19 AM |
| Drum will not turn except for small loads | GRuggerone | Dryer Repair | 1 | 01-02-2009 05:11 AM |
