My washer was Leaking water at the bottom of the door , there was a worn hole in the bottom of it so ordered a inner door panel and tried again and it leak water again so next I bought a door liner with vent tube again tried again and it leaked, but now I think I kinda figured it out, it looks like it is electrical , because it's like the water is filling to high and the floods, if I shut the water valve off after it fills and it won't leak . Also it's like the control nob dosent advance some time could it be that's why it keeps filling ? Thank you
Make sure there is not problem with the tube going from the water level pressure switch to the tub, and if so, try changing out the pressure switch.
