Just replaced Triple Liip Seal and Bearing Kit on my washer. Turned it on. Everything worked fine, agitating, no leaks the the belt stopped on spin cycle. Pulley on motor is spinning, but the belt is not moving. Please help.
Sounds like the brakes are hung up and not releasing.
Any idea how to unlock the brakes? The drum turns when I spin it by hand, in both directions.
If the drum is turning then the brakes are probably ok and the problem is the transmission.
See how hard it is turn the transmission pulley.
The transmission pulley turns easily. The spin cycle worked fine until I changed the hub seal. Is there something I could have done wrong with the installation?
