Discuss
No hot/cold water solenoid is good, where to next?
 in
Washer Repair
First I searched for but did not have luck finding my answer. I have a Kenmore Elite top load, I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » No hot/cold water solenoid is good, where to next?
  #1 (permalink)
Old 08-24-2011, 07:15 PM
Junior Member
Samandothers is on a distinguished road
Default No hot/cold water solenoid is good, where to next?
Model Number: 11016972   Brand: Kenmore   Age: 1 - 5 years
I have a Kenmore Elite top load, I believe manufactured by Whirlpool. There is no hot water when you attempt to wash in warm or hot water. I removed case and checked the resistance of the solenoids on the Hot and Cold water value and they were both about 800 ohms. I don't want to buy a valve since I have read this measurement could be up to 1000 ohms, besides it is $100.
Where to next? What controls the solenoids and how might I check?
I have not found a service manual yet to help determine how to troubleshoot. I would appreciate some help on what to check. Thanks!
I first wrongly posted in Ovens section. Sorry about that...
Related Models
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
Kenmore 11017812600 RESIDENTIAL WASHER
Kenmore 11018112700 RESIDENTIAL WASHER
Kenmore 11018202790 AUTOMATIC WASHER
Kenmore 1101820296 LAUNDRY CENTER
Kenmore 1101820299 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11018212700 RESIDENTIAL WASHER
Kenmore 11018212701 WASHER
Kenmore 11018522790 AUTOMATIC WASHER
Kenmore 11018522791 AUTOMATIC WASHER
Kenmore 11018532790 AUTOMATIC WASHER
Kenmore 11018542890 AUTOMATIC WASHER
Kenmore 11018542891 AUTOMATIC WASHER
Kenmore 11018609890 AUTOMATIC WASHER
Kenmore 11018702790 AUTOMATIC WASHER
Kenmore 11018702791 AUTOMATIC WASHER
Kenmore 11018812700 RESIDENTIAL WASHER
Kenmore 11018812701 RESIDENTIAL WASHER
Kenmore 11019101990 AUTOMATIC WASHER-GALAXY
Kenmore 11019101991 AUTOMATIC WASHER-GALAXY
Kenmore 11019101992 WASHER
Kenmore 11019202200 AUTOMATIC WASHER-GALAXY
Kenmore 11019422200 AUTOMATIC WASHER-GALAXY
Hoover 1102
Kenmore 11020022010 WASHER
Kenmore 11020022011 AUTOMATIC WASHER
Kenmore 11020052990 WASHER
Kenmore 11020052991 WASHER
Kenmore 11020052992 WASHER
Kenmore 11020052993 AUTOMATIC WASHER
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056993 AUTOMATIC WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11020097993 WASHER
Kenmore 11020112000 COMMERCIAL AUTOMATIC WASHER
Kenmore 1102011200A WASHER
Kenmore 11020132000 COMMERCIAL AUTOMATIC WASHER
Kenmore 11020132001 WASHER
Kenmore 11020172000 COMMERCIAL AUTOMATIC WASHER
Kenmore 11020172001 COMMERICAL AUTOMATIC WASHER
Kenmore 11020272000 COMMERCIAL AUTOMATIC WASHER
Kenmore 11020272001 COMMERICAL AUTOMATIC WASHER
Kenmore 11020402990 AUTOMATIC WASHER
Kenmore 11020412990 AUTOMATIC WASHER
Kenmore 11020412991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020422990 AUTOMATIC WASHER
Kenmore 11020422991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020432990 WASHER
Kenmore 11020432991 WASHER
Kenmore 11020442990 WASHER
Kenmore 11020442991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020522900 AUTOMATIC WASHER
Kenmore 11020602990 AUTOMATIC WASHER
Kenmore 11020602991 AUTOMATIC WASHER
Kenmore 11020602992 WASHER
Kenmore 11020612990 AUTOMATIC WASHER
Kenmore 11020612991 AUTOMATIC WASHER
Kenmore 11020622990 AUTOMATIC WASHER
Kenmore 11020622991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020632990 AUTOMATIC WASHER
Kenmore 11020632991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020642990 WASHER
Kenmore 11020642991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020692000 COMPACT WASHER
Kenmore 11020692001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020702990 AUTOMATIC WASHER
Kenmore 11020702991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020712990 AUTOMATIC WASHER
Kenmore 11020712991 WASHER
Kenmore 11020722990 AUTOMATIC WASHER
Kenmore 11020722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020802990 AUTOMATIC WASHER
Kenmore 11020802991 WASHER
Kenmore 11020832990 AUTOMATIC WASHER
Kenmore 11020832991 WASHER
Kenmore 11020842990 AUTOMATIC WASHER
Kenmore 11020842991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020852990 AUTOMATIC WASHER
Kenmore 11020852991 WASHER
Kenmore 11020854990 AUTOMATIC WASHER
Kenmore 11020854991 WASHER
Kenmore 11020857990 AUTOMATIC WASHER
Kenmore 11020862990 AUTOMATIC WASHER
Kenmore 11020862991 WASHER
Kenmore 11020872990 AUTOMATIC WASHER
Kenmore 11020872991 WASHER
Kenmore 11020882990 AUTOMATIC WASHER
Kenmore 11020882991 WASHER
Kenmore 11020892990 AUTOMATIC WASHER
Kenmore 11020892991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020894990 AUTOMATIC WASHER
Kenmore 11020894991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020897990 AUTOMATIC WASHER
Kenmore 11020901990 AUTOMATIC WASHER
Kenmore 11020901991 AUTOMATIC WASHER, COMPACT A/W
  #2 (permalink)
Old 08-25-2011, 03:14 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Your model number is missing several digits at the end.
Sears model numbers ate usally 3 digits, a period and then 8 digits.
Just because a water valve measures OK for resistance does not mean that it is actually opening.
Turn off the hot water tap.
Undo the hose at the machine and run some water into a pail, to be sure hot water is reaching the machine.
If OK
Look into the machines hot water valve and check that the filter screen on the input side of the valve is clean.
If not clean it. Do not permanently remove it as it is there to keep crud out of the valve which could hold the valve open and cause a flood.
If OK.
Reattach the hose, unplug the unit and switch the wires from the hot to the cold and vice versa.
Plug it in and give it a try.
If you still only have cold water, the water valve needs to be replaced.
If it fills with hot water then you know the problem is not the hot water valve, probably the temperature selector switch or timer.
Also if the screen filter is clogged I would drain some water out of your hot water tank as there may be crud in the bottom of it.
__________________
  #3 (permalink)
Old 08-25-2011, 06:00 AM
Junior Member
Default
Thank you for the suggestions. I have validated Hot water to machine end of hose and the screen is clear. I have a follow up question.
If I understand correctly the next action is to remove the wire plug from the cold side of solenoid and plug it the hot side and then plug the one from the hot side to the cold and attempt to run the machine.
Your Comment:
'Plug it in and give it a try.
If it fills with hot water then you know the problem is not the hot water valve, probably the temperature selector switch or timer.'
Is this because the wire now going to Cold side (was from the hot solenoid originally) is sending message (voltage) for cold side to open which it does so you get cold water, yet the valve is not opening when message (voltage) is coming to the input on the Hot side (from wires originally working when connected to cold side)?
Just want to make sure I understand the trouble shooting technic. Thank you again this makes sense as a way to check it out.
  #4 (permalink)
Old 08-25-2011, 07:29 AM
Senior Expert
APP Volunteer
Default
Yes.
You know that the cold valve is getting voltage as it does work. Now you have that voltage on the hot valve so if the valve does not open you know that the valve is toast.
Be sure to use a warm or cold setting.
__________________
  #5 (permalink)
Old 08-25-2011, 07:39 PM
Junior Member
Default swapped the electrical connections
Made the suggested changes and also found model number 110.16972500.
Ok, here's the deal...originally when I would set the machine to wash in warm it would begin to dispense cold water and then when it was supposed to dispense hot to mix in, the machine would make a screeching noise but dispense nothing other than the cold.
Now after swapping the electrical connections the water temps are complete opposite. It started filling with hot and then screeched and continued filling with hot only.
So what does that mean?
signed...The most important Other-the one that uses the machine.
Thanks for continued help!
  #6 (permalink)
Old 08-27-2011, 02:57 AM
Senior Expert
APP Volunteer
Default
Sears has a parts breakdown for this unit which may help.
See the attachment for the tech sheet for this unit.
You now know that both valves work so the problem is deeper in the machine.
At the top of my list would be the ATC (temperature control) board.
It determines which valve to open and when.
__________________
  #7 (permalink)
Old 08-28-2011, 02:56 PM
Junior Member
Default
Thank you for the follow up I have ordered the temperature control switch. It should be in next week and I'll give it a shot.
  #8 (permalink)
Old 09-26-2011, 05:53 PM
Junior Member
Default
Hubby replaced the temp control switch and I have been enjoying using variable temperatures again! Thanks for all the help! You are AWESOME!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No hot/cold water solenoid is good, where to next? Samandothers Oven Repair (including Ranges and Cooktops) 2 08-25-2011 03:16 AM
fridge not cold freezer good djhooter Refrigerator & Freezer Repair 1 02-23-2010 05:08 PM
Good cold water but no ice cubes thom2003 Refrigerator & Freezer Repair 0 02-14-2010 03:27 PM
LG WF 651 cold water solenoid constantly energized McMaddles Washer Repair 0 11-23-2009 04:39 PM
Refrigerator good but freezer not cold enough JoeP Refrigerator & Freezer Repair 7 11-30-2007 07:28 PM
