Discuss
how can I fix it
 in
Washer Repair
I start it up on any cycle. the basket fills. after it fills it hums for a few seconds then
Appliance Repair Forum > Appliance Repair Help > Washer Repair » how can I fix it
  #1 (permalink)
Old 08-24-2011, 05:58 PM
Junior Member
gammmbler is on a distinguished road
Default how can I fix it
Model Number: lsr7010pq2   Brand: Whirlpool   Age: 1 - 5 years
I start it up on any cycle. the basket fills. after it fills it hums for a few seconds then the gfci outlet trips and the washer stops huming (of course...l.no power) I stop the washer (setting control) and re-set the gfci. when I start the washer it just hums...... I was told it was the water pump....I have already ordered one. could it be perhaps a plug not connected? or a circuit board? the motor? What seems the most likely??? the machine is about 5 or 6 years old and was totally dependable until this problem..
Ads By Google
Related Models
Whirlpool LSR7010PQ2 Automatic Washer
Whirlpool LSR7133KQ0
Whirlpool LSR7133KQ1 Automatic Washer
Whirlpool LSR7133PQ0 Automatic Washer
Whirlpool LSR7133PQ1 Automatic Washer
Whirlpool LSR7133PQ2 Automatic Washer
Whirlpool LSR7200EQ0
Whirlpool LSR7200EZ0
Whirlpool LSR7233BG0
Whirlpool LSR7233BG1
Whirlpool LSR7233BG2
Whirlpool LSR7233BN0
Whirlpool LSR7233BN1
Whirlpool LSR7233BN2
Whirlpool LSR7233BQ0
Whirlpool LSR7233BQ1
Whirlpool LSR7233BQ2
Whirlpool LSR7233BW0
Whirlpool LSR7233BW1
Whirlpool LSR7233BW2
Whirlpool LSR7233BZ0
Whirlpool LSR7233BZ2
Whirlpool LSR7233DQ0
Whirlpool LSR7233DQ1
Whirlpool LSR7233DW0
Whirlpool LSR7233DZ0
Whirlpool LSR7233DZ1
Whirlpool LSR7233EQ0
Whirlpool LSR7233EQ1
Whirlpool LSR7233EW0
Whirlpool LSR7233EZ0
Whirlpool LSR7233EZ1
Whirlpool LSR7233HQ0
Whirlpool LSR7233HZ0
Whirlpool LSR7300PQ0 Automatic Washer
Whirlpool LSR7300PQ1 Automatic Washer
Whirlpool LSR7300PQ2 Automatic Washer
Whirlpool LSR7333PQ0 Automatic Washer
Whirlpool LSR7333PQ1 Automatic Washer
Whirlpool LSR7333PQ3 Automatic Washer
Whirlpool LSR7333PQ4 Automatic Washer
Whirlpool LSR8010PQ0 Automatic Washer
Whirlpool LSR8010PQ1 Automatic Washer
Whirlpool LSR8010PQ2 Automatic Washer
Whirlpool LSR8010PT0 Automatic Washer
Whirlpool LSR8010PT1 Automatic Washer
Whirlpool LSR8010PT2 Automatic Washer
Whirlpool LSR8133HQ0
Whirlpool LSR8133HZ0
Whirlpool LSR8200EQ0
Whirlpool LSR8200EZ0
Whirlpool LSR8233EQ0
Whirlpool LSR8233EQ1
Whirlpool LSR8233EZ0
Whirlpool LSR8233EZ1
Whirlpool LSR8233JQ0
Whirlpool LSR8233JQ1
Whirlpool LSR8233JT0
Whirlpool LSR8233JT1
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0
Whirlpool LSR8433KQ1 Automatic Washer
Whirlpool LSR8433KQ2 Automatic Washer
Whirlpool LSR8433KT0
Whirlpool LSR8433KT1 Automatic Washer
Whirlpool LSR8433KT2 Automatic Washer
Whirlpool LSR8444LQ0
Whirlpool LSR8444LQ1 Automatic Washer
Whirlpool LSR8444LT0
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 Automatic Washer
Whirlpool LSR9434PQ1 Automatic Washer
Whirlpool LSR9434PQ3 Automatic Washer
Whirlpool LSR9434PQ4 Automatic Washer
Whirlpool LSR9434PT0 Automatic Washer
Whirlpool LSR9434PT1 Automatic Washer
Whirlpool LSR9434PT3 Automatic Washer
Whirlpool LSR9434PT4 Automatic Washer
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0
Whirlpool LSS9244EZ0
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
  #2 (permalink)
Old 08-26-2011, 01:14 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
You need to take off the cabinet and see if the pump is obstructed, if there is a problem with a broken or jammed coupling, if the motor is bad or if the transmission is the problem. All of those would produce the symptoms you describe.
If you are just ordering parts without knowing what is wrong you will just end up with a big parts bill.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
