Okay. So my washer was not spinning and was giving an error code. My dad came to look at it and said that the code was for the motor. We replaced the motor and it still didn't work so he called GE and they said that it just meant that the motor couldn't complete the cycle and to try the inverter. I need to find out the part number for the inverter, but I am not sure how to find that out. Upon further inspection my dad said that I needed a new boot because mine had a hole in it and was leaking water and that was likely the start to the whole problem. So how would I find out that part number. Upon searching on the internet I found another washer that looks just like mine but has a model number of wcvh6260fww and mine is wbvh6240fww... what is the difference in these two models. Any help would be greatly appreciated as I am lost when it comes to this stuff. I just want to get my washer running again and I do not want to spend any more money than I have to as I am already out almost 200 for the first part. Thanks, Myranda
