Discuss
Tub won't spin unless you open & close the lid
 in
Washer Repair
I have the same problem. If I hear the machine stop agitating and then go to tub drain/spin cycle, I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Tub won't spin unless you open & close the lid
  #1 (permalink)
Old 08-21-2011, 10:36 PM
Junior Member
jhonster is on a distinguished road
Default Tub won't spin unless you open & close the lid
Model Number: 11022722101   Brand: Kenmore   Age: 5 - 10 years
I have the same problem. If I hear the machine stop agitating and then go to tub drain/spin cycle, I hear the pump draining the tub....but it won't spin unless I open and reclose the lid. There is a pause between the agitation cycle and the tub drain/spin cycle, so does that mean my timer is cutting the power? I'm just not sure if replacing the timer would be the total fix for my scenario. Anyway to verify this?
I've been an automotive mechanic for 35 years, so electrical and mechanic equipment isn't an issue for me. So please don't be shy in explaining something technically to me.
Thanks in advance for any help. Its much appreciated. I already replaced the clutch assembly and now the machine doesn't have the loud "clack" noise when the tub does actually spin in the latter spin cycle.
Ads By Google
Related Models
Kenmore 11023012100 AUTOMATIC WASHER
Kenmore 11023012101 AUTOMATIC WASHER
Kenmore 11023012102 AUTOMATIC WASHER
Kenmore 11023014100 AUTOMATIC WASHER
Kenmore 11023014101 AUTOMATIC WASHER
Kenmore 11023014102 AUTOMATIC WASHER
Kenmore 11023022100 AUTOMATIC WASHER
Kenmore 11023022101 AUTOMATIC WASHER
Kenmore 11023022102 AUTOMATIC WASHER
Kenmore 11023024100 AUTOMATIC WASHER
Kenmore 11023024101 AUTOMATIC WASHER
Kenmore 11023024102 AUTOMATIC WASHER
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
Kenmore 11023822100 AUTOMATIC WASHER
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
Kenmore 11023904201 AUTOMATIC WASHER
Kenmore 11023912100 AUTOMATIC WASHER
Kenmore 11023912101 AUTOMATIC WASHER
Kenmore 11023912102 AUTOMATIC WASHER
Kenmore 11023922200 AUTOMATIC WASHER
Kenmore 11023922201 AUTOMATIC WASHER
Kenmore 11023924200 AUTOMATIC WASHER
Kenmore 11023924201 AUTOMATIC WASHER
Kenmore 11023932200 WASHER
Kenmore 11023934200 WASHER
Kenmore 11024082200 AUTOMATIC WASHER
Kenmore 11024084200 AUTOMATIC WASHER
Kenmore 11024086200 AUTOMATIC WASHER
Kenmore 11024422300 AUTOMATIC WASHER
Kenmore 11024432300 AUTOMATIC WASHER
Kenmore 11024442300 AUTOMATIC WASHER
Kenmore 11024622300 AUTOMATIC WASHER
Kenmore 11024632300 AUTOMATIC WASHER
Kenmore 11024642300 AUTOMATIC WASHER
Kenmore 11024652300 AUTOMATIC WASHER
Kenmore 11024692300 AUTOMATIC WASHER
Kenmore 11024812200 AUTOMATIC WASHER
Kenmore 11024812201 AUTOMATIC WASHER
Kenmore 11024822200 AUTOMATIC WASHER
Kenmore 11024822201 AUTOMATIC WASHER
Kenmore 11024832200 AUTOMATIC WASHER
Kenmore 11024832201 AUTOMATIC WASHER
Kenmore 11024892300 AUTOMATIC
Kenmore 11024894300 AUTOMATIC
Kenmore 11024902200 AUTOMATIC WASHER
Kenmore 11024902201 AUTOMATIC WASHER
Kenmore 11024904200 AUTOMATIC WASHER
Kenmore 11024904201 AUTOMATIC WASHER
Kenmore 11024922200 AUTOMATIC WASHER
Kenmore 11024922201 AUTOMATIC WASHER
Kenmore 11024924200 AUTOMATIC WASHER
Kenmore 11024924201 AUTOMATIC WASHER
Kenmore 11024932200 AUTOMATIC WASHER
Kenmore 11024932201 AUTOMATIC WASHER
Kenmore 11024934200 AUTOMATIC WASHER
Kenmore 11024934201 AUTOMATIC WASHER
Kenmore 11024942300 AUTOMATIC WASHER
Kenmore 11024944300 AUTOMATIC WASHER
Kenmore 11024946300 AUTOMATIC WASHER
Kenmore 11024952300 AUTOMATIC WASHER
Kenmore 11024954300 AUTOMATIC WASHER
Kenmore 11024956300 AUTOMATIC WASHER
Kenmore 11024962300 AUTOMATIC WASHER
Kenmore 11024964300 AUTOMATIC WASHER
Kenmore 11024966300 AUTOMATIC WASHER
Kenmore 11024972300 AUTOMATIC WASHER
Kenmore 11024974300 AUTOMATIC WASHER
Kenmore 11024982300 AUTOMATIC WASHER
Kenmore 11024992300 AUTOMATIC WASHER
Kenmore 11024994300 AUTOMATIC WASHER
Kenmore 11024996300 AUTOMATIC WASHER
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026702694 AUTOMATIC WASHER
Kenmore 11026722690 WASHER
Kenmore 11026801690 AUTOMATIC WASHER
Kenmore 11026812690 WASHER
Kenmore 11026814690 WASHER
Kenmore 11026822690 WASHER
Kenmore 11026824690 WASHER
Kenmore 11026824692 AUTOMATIC WASHER
Kenmore 11026832690 AUTOMATIC WASHER
Kenmore 11026832694 AUTOMATIC WASHER
Kenmore 11026834690 WASHER
Kenmore 11026834694 AUTOMATIC WASHER
Kenmore 11026842690 WASHER
Kenmore 11026842694 AUTOMATIC WASHER
Kenmore 11026844690 WASHER
Kenmore 11026844694 AUTOMATIC WASHER
Kenmore 11026892690 TB26-10- WARM RINSE
Kenmore 11026901690 SUPER CAPACITY PLUS AUTOMATIC WASHER
Kenmore 11026901692 AUTOMATIC WASHER
  #2 (permalink)
Old 08-22-2011, 06:10 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I am assuming this is a direct drive Whirlpool made machine.
Your machine has a neutral drain, meaning when it starts to drain the transmission shifts into neutral so it is not trying to turn the tub while it is full of water.
The timer needs to pause the motor after the drain is complete. This causes the transmission to shift into spin. If the motor does not pause, no shift. So the timer is not doing its "pause" job, and when you open and close the lid you are doing the pause job for it. That is why it starts spinning after you do that.
So replacing the timer should fix your problem.
__________________
  #3 (permalink)
Old 08-25-2011, 07:10 AM
Junior Member
isubucky is on a distinguished road
Default
I have been fighting what appears as a similar issue as the OP. Whirlpool direct drive (LSR7233EQ0, about 15 years old). As the OP stated, washer fills, agitates (2 steps), the pump drains the drum, but the drum does not spin. If I open the lid after the pump starts to drain and reclose (couple second delay) the drum will spin. Same behavior occurs on the rinse cycle. In my case there is a PAUSE between agitation and drain.
I have replaced the clutch (kit), the neutral drain (kit), and motor coupling, and still the same behavior.
I am not convinced it is the timer since the pause between agitate and drain/spin is quite apparent. However the only part I have left is the Brake and Drive tube.
Running out of options and looking for suggestions...
Good news, I can disassemble this thing pretty quickly....
To the OP, not intending to threadjack, but based on the symptoms I hope both can benefit.
  #4 (permalink)
Old 08-25-2011, 09:35 AM
Senior Expert
APP Volunteer
Default
Once it starts to drain it is in neutral. If you open the lid and interrupt the drain it will cause the machine to shift into spin.
Replace the timer, that should fix your problem.
__________________
  #5 (permalink)
Old 08-25-2011, 10:58 AM
Junior Member
Default
Thanks, I will try that!
  #6 (permalink)
Old 08-26-2011, 07:12 AM
Junior Member
Default
The local appliance store does not have a timer in stock, so waiting until next week to get one. In the meantime, is there any way to jumper it to temporarily "get by" and confirm that is the issue?
Also, I would like to better understand the role of the time in the spin cycle. I understand that the time ultimately switches power to the motor (in my case the motor appears to be running correctly). However, I do not understand how the timer controls tub spin. That looks mechanical to me.
Thanks!
  #7 (permalink)
Old 08-26-2011, 09:39 AM
Senior Expert
APP Volunteer
Default
I do not know of any way to test the timer. The test is basically what you have done, when you open the lid you mimic the timer stopping the motor to allow the shift out of neutral to take place.
You can try turning the timer vigorously for about 15 seconds, sometimes that will give you a temporary fix.
If you buy from the part from this site you will probably get it less expensive and you can return it if it does not fix the problem (no, those of us who respond do not work for APP, we are volunteers who do not receive any compensation from the company, so we can recommend them with independence)
__________________
  #8 (permalink)
Old 08-26-2011, 11:07 AM
Junior Member
Default
Thanks for the info, sorry for all the questions, just trying to understand how it works.
I ran it through a wash cycle this morning...
1. Fill
2. Hi Agitate
3. Brief Pause (did not count the time)
4. Low Agitate
5. 5 second pause
6. Drain but no spin (30 seconds)
7. Opened the lid and closed
8. Drain and spin
  #9 (permalink)
Old 08-26-2011, 11:54 AM
Senior Expert
APP Volunteer
Default
This service manual will explain the neutral drain and why the motor pause is necessary to shift the transmission in far more detail than you really want to know
https://secured.whirlpool.com/Servic...$FILE/L-55.pdf
but then you say you really want to know.
__________________
  #10 (permalink)
Old 04-28-2012, 05:12 PM
Junior Member
shmoozer is on a distinguished road
Default
Well, any feedback? Mine is doing the same and I did clean the contacts inside the timer several years ago. I cleaned them again; only one seemed burned. I have a 11092583810 Kenmore Washer. The cheapest timer I found was on (withheld) for $89 but now I'll check this site for a price. I would rather just replace the contacts if they can be purchased. Can I buy just the contact pack for the washer instead of buying the whole timer?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer wont spin unless i open then close lid idrinkalone Washer Repair 3 08-22-2011 01:57 AM
LG frontloader door won't open/close pmaldrum Washer Repair 1 07-18-2011 04:50 PM
ice door won't open or close wkames Refrigerator & Freezer Repair 1 09-01-2010 02:36 PM
refridgerator door will not close by itself and will open by itself moonra00kc@yahoo.com Refrigerator & Freezer Repair 0 12-15-2009 06:32 AM
Maytag Washing won't spin & drain unless open & close lid hull98 Washer Repair 1 09-19-2009 04:15 PM
