Discuss
Tub won't spin unless you open & close the lid
 in
Washer Repair
Originally Posted by shmoozer Well, any feedback? Mine is doing the same and I did clean the contacts inside the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Tub won't spin unless you open & close the lid
  #21 (permalink)
Old 03-06-2018, 09:14 AM
Junior Member
shmoozer is on a distinguished road
Default
Quote:
Originally Posted by shmoozer View Post
Well, any feedback? Mine is doing the same and I did clean the contacts inside the timer several years ago. I cleaned them again; only one seemed burned. I have a 11092583810 Kenmore Washer. The cheapest timer I found was on (withheld) for $89 but now I'll check this site for a price. I would rather just replace the contacts if they can be purchased. Can I buy just the contact pack for the washer instead of buying the whole timer?
I'm sorry for the late update. My issue turned out to be the speed control selector switch. Somehow, playing with the lid and controls would make contact inside the switch. Pushing on the knob of the speed control made the connection. I ended up purchasing a new washer last year- what a mistake.
  #22 (permalink)
Old 03-06-2018, 10:21 AM
Junior Member
BeardGuy1977 is on a distinguished road
Default
It is a Belt Drive machine... not a direct drive. Does this change things?
and BTW... I cant open and close lid since it stays locked throughout whole wash cycle. So any other ideas...
and lastly... it is a 2014 Whirpool New style Belt drive.
  #23 (permalink)
Old 03-06-2018, 11:06 AM
Junior Member
Default
Quote:
Originally Posted by sidfink43 View Post
I am assuming this is a direct drive Whirlpool made machine.
Your machine has a neutral drain, meaning when it starts to drain the transmission shifts into neutral so it is not trying to turn the tub while it is full of water.
The timer needs to pause the motor after the drain is complete. This causes the transmission to shift into spin. If the motor does not pause, no shift. So the timer is not doing its "pause" job, and when you open and close the lid you are doing the pause job for it. That is why it starts spinning after you do that.
So replacing the timer should fix your problem.
and lastly... it is a 2014 Whirpool New-style Belt drive.
  #24 (permalink)
Old 03-06-2018, 12:42 PM
Junior Member
LoXodonte is on a distinguished road
Default
My warranty company is sending an appliance dude back out...I'll remember to post whatever he tells me but I'd take it with a grain of salt considering he either 1.) he put it back together incorrectly. or 2.) failed to test thoroughly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer wont spin unless i open then close lid idrinkalone Washer Repair 3 08-22-2011 01:57 AM
LG frontloader door won't open/close pmaldrum Washer Repair 1 07-18-2011 04:50 PM
ice door won't open or close wkames Refrigerator & Freezer Repair 1 09-01-2010 02:36 PM
refridgerator door will not close by itself and will open by itself moonra00kc@yahoo.com Refrigerator & Freezer Repair 0 12-15-2009 06:32 AM
Maytag Washing won't spin & drain unless open & close lid hull98 Washer Repair 1 09-19-2009 04:15 PM
