| » G.E. Adora Front Load |
Model Number: WHDVH626FWW Brand: GE Age: 1 - 5 years
Just wondering 3 things on the GE Adora front load washer WHDVH626FWW door lock. 1) are the solenoids, (in red) line voltage (120 volt) or low voltage? 2) are the micro switch contacts, (in green), opened in the unlock or locked position? 3) what is the purpose of dual contacts (green), if it is, as it appears, a single throw switch? (or maybe it isn't a single throw switch ??? ) Oh, lets make that 4 things. 4) on my machine the display reads "DOOR LOCK" continuously even though it is Unlocked, so I am assuming the contacts are not opening, (or closing depending on question #2) thus I need to break open the door lock assembly and clean and lube it. Any pointers in doing this, Small parts, spring loads that will fly out, etc. to be cautionish of? Thanks in advance for any answers. Brad. . Ads By Google Related Models |
Hmm,
I jumpered out pins 4 & 5 and 6 & 7 and still get a Door Lock on the display. Also, I have cleaned the filter, pump runs fine and pumps out fine. Wondering if I'm on the right track or maybe it is something else like the water level pressure switch? Any thoughts ? TIA Brad Last edited by Bradster941 : 08-22-2011 at 12:09 PM. |
| Display Modes | |
| Replace front door seals on front load whirlpool washer | andy202746@verizon.net | Washer Repair | 0 | 08-06-2011 11:22 AM |
| GE Adora Front Door Boot Gasket - Part Number Woes | proton17 | Washer Repair | 3 | 01-03-2011 06:17 PM |
| ge top load adora washer | lhfitz | Washer Repair | 0 | 07-15-2010 12:53 PM |
| Torn Gasket GE Adora Front Loader Washer | rsegalla@verizon.net | Washer Repair | 0 | 12-30-2009 08:14 AM |
| Load Thumping Noise & Unbalanced Condition On GE front load washer | Luke Vincent | Washer Repair | 2 | 08-06-2009 05:43 PM |
