| » Front load will not spin |
Model Number: CRTR9300ASO Brand: Frigidaire Age: 5 - 10 years
drum motor is trying to run but only squeaks. Checked capacitors on control board they tested OK. Belt is not slipping, motor just will not go. Watching it trying to run, its like it is stuttering. Every once in a while it will final spin out but only on the final spin.
The tech notes inside the lower service panel should show you how to test the motor/speed control board. Check it out as it is the most likely problem.
Also check the wiring to that board for any breaks or loose connections.
__________________
| Display Modes | |
| Front load no spin | NH3 Doc | Washer Repair | 1 | 09-06-2012 11:39 AM |
| GE front load will not spin at all | adeguisto | Washer Repair | 1 | 07-14-2011 11:11 AM |
| Front load washer won't spin water out of clothes on last spin cycle | Tracey Finley | Washer Repair | 1 | 06-28-2011 05:10 PM |
| GE front load will not spin please help | smhope2020 | Washer Repair | 7 | 06-07-2011 03:04 PM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
