Discuss
banging,walking maytag performa
 in
Washer Repair
The unit, during the spin cycle, will bang, clank, and walk as far as the water supply and drain hoses
Appliance Repair Forum > Appliance Repair Help > Washer Repair » banging,walking maytag performa
  #1 (permalink)
Old 11-26-2007, 09:43 AM
cwilson cwilson is offline
Junior Member
cwilson is on a distinguished road
Default banging,walking maytag performa
Model Number: PAVT344AWW   Brand: Maytag   Age: 5 - 10 years
The unit, during the spin cycle, will bang, clank, and walk as far as the water supply and drain hoses will let it. (If I'm not home my wife will push it back -straining her neck and back) The belt has been replaced & the floor and unit are completely level. The problem has gotten progressively worse over the past weeks/months and the contents now have to be re-adjusted 2-4x's during spins to complete cycle. On reviewing previously posted threads it appears 'snubber replacement' may be in order. Please advise as to appropriateness/difficulty of this. I am competent mechanically and have a well equipped shop but do not have specialty appliance tools. Thank you for your advice and time-they are valued.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-26-2007, 08:20 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The complete instructions you can find in the service manual.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-27-2007, 05:08 AM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default check
check to make sure you don't have broken spring down below. and make sure your automatic leveler is working. if they are ok. put a couple of sand paper dicus under your front legs. stick the dicus to the floor.this should take care of the walking. even if the washer is level and if your floor is not. I found at one guys house his floor was about a inch off . with the sand paper dicus. it took care of his walking.
  #4 (permalink)
Old 12-04-2007, 05:08 PM
JLM81 JLM81 is offline
Junior Member
JLM81 is on a distinguished road
Default leveler question
I have a Gibson stackable model number MLCE52RCS1. I was looking at the washer-drive assembly drawing (11), and I can't tell if there are two part 6's or two part 5's. The one with the counterspring--looks like part 6, so a base, is bent. (1) Am I reading the part number for the one with the counter spring correctly? (2) Because this is bent, is it necessary to replace the other ones? (3) Should I replace the counter spring as well? (4) There appears to be a set of slots for 2 countersprings on that one base, but only one spring--should there be two?
Thanks.
  #5 (permalink)
Old 12-05-2007, 01:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
My first question: what exactly is wrong with your washer?
What had you to take it apart?
__________________
  #6 (permalink)
Old 12-05-2007, 10:20 PM
Junior Member
Default
My machine had been getting off balance, but I thought it was how I was placing the load. Then, one night it completely fell off back to the back right hand corner. I took it apart to see if I could reseat it, and realized that the bolt on the base was bent. The counter-spring was still attached.
  #7 (permalink)
Old 12-06-2007, 02:32 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
For cwilson, you have the classic snubber problem.
__________________
  #8 (permalink)
Old 12-06-2007, 11:30 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Thanks.
(1) The counterweight spring (drawing #4), part number AP2147314
(2) If I got you right, when you said "the bolt on the base was bent" you meant the suspension assembly or leveler (drawing #5) with part number AP2147315 ?
You do not have to replace all three. Replace only what was damaged.
Did you check the tub support (drawing #19) for any damages?
(3) If the counterweight spring is not worn out and/or not damaged you do not have to replace it.
(4) There is only one counterweight spring.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Performa Washer won't spin or wash on regular cycle gidy34 Washer Repair 1 11-14-2007 10:54 AM
dryer drum banging noise a2home Dryer Repair 1 10-12-2007 03:14 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
