| » error code F22 |
Model Number: wfw9400su00 Brand: Whirlpool Age: 1 - 5 years
My washer control panel was dead. I installed a control panel I purchased from Appliance Parts Pros, and now I get the error code F22 and sometimes F02. What is error code F22? Thanks
After changing out the door switch, I still get the f22. When I open and shut the door a couple times, it switches to f02. F02 is the drain pump. Are they related?
The CCU is sending the right voltage to the IU, but only the error codes respond when plugging in washer. I can,t run diagnostic.Error codes do cancel when pause/cancel is pushed, but nothing else seem to light or respond. The door switch I bought from appliance parts pros has the same ohm readings as the old one, but not what the manual says they should be. Too many things going on to narrow it down. appreciate the help
| Display Modes | |
| LG error code OE - drain error | JPotter | Washer Repair | 0 | 04-01-2011 07:20 AM |
| Error code E68 | randress | Dryer Repair | 1 | 01-01-2011 04:35 AM |
| F3 code error | mckinneyrocks | Oven Repair (including Ranges and Cooktops) | 0 | 06-26-2010 02:18 PM |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
| error code | jaxxxter | Oven Repair (including Ranges and Cooktops) | 0 | 10-22-2009 04:26 PM |
