washer started to smell like smoke then, i shut down not just makes noise like jamed have a new transmition how do i diagnos?
I just replaced the water pump on my Maytag two days ago because the bearing in the water pump pulley went bad, and that caused my washer to jam and smell like something burning. The water pump is fairly easy to replace.
