Discuss
Whirlpool Washer Needs Fixing
 in
Washer Repair
Very old Whirlpool washer (could be from 1971 or 1981 says Hannah the parts tech I spoke with). This is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer Needs Fixing
  #1 (permalink)
Old 08-19-2011, 12:45 PM
Junior Member
CEDRIC_W is on a distinguished road
Default Whirlpool Washer Needs Fixing
Model Number: LWA5545W3   Brand: Whirlpool   Age: More than 10 years
This is to be a back up washer as the older Whirlpools were quality machines prior to 2000.
This one buzzes when I pull out the off on switch and starts filling with water. After that (without filling the tub completely) does not agitate or spin.
I will fill the tub completely and see if it agitates (just thought of that as I write this).
If that doesn't work, I need to know what switches in the controls need to be tested and/or replaced.
If the problem is not in the control switches, I will need to check out the agitator motor area and spin controls in that area.
Any advice will be appreciated.
UPDATE: Just let the washer fill on a small load setting (water rose to top of the blades of the agitator). The buzzing sound stopped, silence for a few seconds, then another sound like the washer was attempting to move to the next cycle which lasted maybe five seconds, then a silent pause again. Then the same sound again for another five seconds or so, then nothing. Moved the load size selector to large and the machine started filling again. Switched back to small load size and the machine made the same sounds a few times then went silent. I turned the selector switch through all the selections, but nothing. Hope this new info helps.
Cedric W
Ads By Google
Related Models
Whirlpool LWA5545W3
Whirlpool LWA5560W3
Whirlpool LWA5565W3
Whirlpool LWA5800W0
Whirlpool LWA5800W1
Whirlpool LWA5800W2
Amana LWA60AL Washer - Top Loading
Amana LWA60AW Washer - Top Loading
Whirlpool LWA6400W0
Whirlpool LWA6400W2
Whirlpool LWA6400W3
Whirlpool LWA6400W4
Whirlpool LWA6400W5
Whirlpool LWA6400W6
Whirlpool LWA6404W0
Whirlpool LWA6404W2
Whirlpool LWA6404W3
Whirlpool LWA6404W4
Whirlpool LWA6405W0
Whirlpool LWA6405W2
Whirlpool LWA6405W3
Whirlpool LWA6405W4
Whirlpool LWA6405W5
Whirlpool LWA6405W6
Whirlpool LWA6409W0
Whirlpool LWA6409W2
Whirlpool LWA6409W3
Whirlpool LWA6409W4
Whirlpool LWA6460W0
Whirlpool LWA6460W3
Whirlpool LWA6464W0
Whirlpool LWA6465W0
Whirlpool LWA6465W3
Whirlpool LWA6469W0
Amana LWA65AL Washer - Top Loading
Amana LWA65AW Washer - Top Loading
Whirlpool LWA6600W0
Whirlpool LWA6600W2
Whirlpool LWA6600W3
Whirlpool LWA6604W0
Whirlpool LWA6604W2
Whirlpool LWA6604W3
Whirlpool LWA6605W0
Whirlpool LWA6605W2
Whirlpool LWA6605W3
Whirlpool LWA6609W0
Whirlpool LWA6609W2
Whirlpool LWA6609W3
Whirlpool LWA6660W0
Whirlpool LWA6660W2
Whirlpool LWA6660W3
Whirlpool LWA6664W0
Whirlpool LWA6665W0
Whirlpool LWA6665W2
Whirlpool LWA6665W3
Whirlpool LWA6669W0
Whirlpool LWA6800W0
Whirlpool LWA6800W1
Whirlpool LWA6800W4
Whirlpool LWA6800W5
Whirlpool LWA6805W0
Whirlpool LWA6805W1
Whirlpool LWA6805W6
Whirlpool LWA6860W0
Whirlpool LWA6860W1
Whirlpool LWA6900W0
Whirlpool LWA6900W1
Whirlpool LWA6900W2
Whirlpool LWA6904W1
Whirlpool LWA7000W1
Whirlpool LWA7000W2
Whirlpool LWA7000W3
Whirlpool LWA7005W1
Whirlpool LWA7005W2
Whirlpool LWA7005W3
Whirlpool LWA7500W1
Whirlpool LWA7500W2
Whirlpool LWA7500W3
Whirlpool LWA7505W1
Whirlpool LWA7505W2
Whirlpool LWA7505W3
Whirlpool LWA7700W0
Whirlpool LWA7700W1
Whirlpool LWA7700W2
Whirlpool LWA7700W5
Whirlpool LWA7700W7
Whirlpool LWA7700W9
Whirlpool LWA7704W0
Whirlpool LWA7704W1
Whirlpool LWA7704W2
Whirlpool LWA7704W5
Whirlpool LWA7704W7
Whirlpool LWA7704W9
Whirlpool LWA7705W0
Whirlpool LWA7705W1
Whirlpool LWA7705W2
Whirlpool LWA7705W5
Whirlpool LWA7705W7
Whirlpool LWA7705W9
Whirlpool LWA7709W0
Whirlpool LWA7709W1
Whirlpool LWA7709W2
Whirlpool LWA7709W5
Whirlpool LWA7709W7
Whirlpool LWA7709W9
Whirlpool LWA7740W0
Whirlpool LWA7740W2
Whirlpool LWA7740W3
Whirlpool LWA7744W0
Whirlpool LWA7745W0
Whirlpool LWA7745W2
Whirlpool LWA7745W3
Whirlpool LWA7749W0
Amana LWA80AL Washer - Top Loading
Amana LWA80AW Washer - Top Loading
Whirlpool LWA8700W0
Whirlpool LWA8700W1
Whirlpool LWA8700W4
Whirlpool LWA8700W5
Whirlpool LWA8704W5
  #2 (permalink)
Old 08-20-2011, 06:11 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I don't think we can give you advice on a machine this old.
If you need a good backup I would buy a used direct drive Whirlpool. They are very good machines, and can be had for $100 - $150 in our area.
Trust me, you will be much happer than if you try or even succeed in repairing the one you have.
__________________
  #3 (permalink)
Old 08-23-2011, 04:06 PM
Junior Member
Default This Very Old Washer Was Going To Substitute For My Broken Kenmore Front Loader
This old Whirlpool was a washer my friend had sitting in his collection of old crap he acquires for parts or for debts people owe him.
Sounds like it is a piece of junk.
He also has an old tub and wringer type washer that actually works! I can always use that in a pinch!
Sears left a message on my broken Kenmore Front loader and I have replied to them..
Good forum so far.
  #4 (permalink)
Old 08-24-2011, 03:52 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You might have a frozen pump on this washer, just remove the back panel and try to move the belt by pulling it to the left. If frozen, remove the top motor nut, pull on the belt to move the motor, then check the pump.
__________________
  #5 (permalink)
Old 08-24-2011, 08:33 AM
Junior Member
Default Thanks For The Tip
Quote:
I'll give that tip a try.
Thanks,
Cedric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Is it worth fixing mlevine Microwave Repair 5 07-07-2011 04:48 PM
need help fixing maytag washer asap please derekjude Washer Repair 3 04-24-2011 07:10 AM
Fixing a leak Jerry Barrett Dishwasher Repair 0 11-14-2010 02:52 PM
Questions on fixing Whirlpool gas dryer no heat problem yzhong Dryer Repair 1 06-05-2010 07:32 PM
GE Washer worth fixing? JuSteve Washer Repair 3 02-09-2010 06:18 PM
