Discuss
Intermitent motor prblem or agitation problem?
 in
Washer Repair
Dear forum,I have a top load GE washer.Right after the machine fillsand it gets into its agitate cycle
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Intermitent motor prblem or agitation problem?
  #1 (permalink)
Old 11-25-2007, 02:29 PM
racer7696@msn.com racer7696@msn.com is offline
Junior Member
racer7696@msn.com is on a distinguished road
Default Intermitent motor prblem or agitation problem?
Model Number: WJSE3110A0WW   Brand: GE   Age: 5 - 10 years
Dear forum,I have a top load GE washer.Right after the machine fillsand it gets into its agitate cycle I get a loud clicking noise.This noise sounds like a relay switch clicking on and off really fast from the motor.If I switch cycles it does not seem to help.I put the machine in service mode and from my understanding there are no fault codes.If this is a motor problem does anyone know any ohms readings or specs to verify if the motor is bad.This also seems to be worse the heavier the machine is loaded up,hope you can help.
Mark
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-26-2007, 02:04 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem with your washer is a bad motor.
The resistance test would not show anything wrong, but it should show more amps then it suppose to be.
- The part number for the motor and clutch assembly AP3160670
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thanksgiving Oven Problem.....its still a Problem! rbmattila Oven Repair (including Ranges and Cooktops) 1 03-03-2008 10:05 AM
Frigidaire washer tub spins during agitation Aaron Wood Washer Repair 2 12-05-2007 09:36 AM
Possible Motor Problem??? Davejb Dishwasher Repair 5 11-16-2007 02:53 PM
no agitation or spinning chartman Washer Repair 0 11-12-2007 08:30 PM
Washer leaks during agitation Chaz Washer Repair 0 11-05-2007 09:38 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
