Discuss
Whirlpool Washer: not spinning
 in
Washer Repair
The washer fills, agitates,pumps out the water as it rinses. but does not spin.I've tried the following: 1.While the machine
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer: not spinning
  #1 (permalink)
Old 08-17-2011, 03:03 PM
Junior Member
RTPM is on a distinguished road
Red face Whirlpool Washer: not spinning
Model Number: LSQ9030PQ!   Brand: Whirlpool   Age: 5 - 10 years
1.While the machine was off,I rotated the drum, turned it on, then it spun but not fast enough.
2. As per a Whirlpool rep's suggestion, I unplugged the machine, waited 3 minutes, plugged it in and the spin cycle operated but not very fast so the garments were very soggy.
What part(s) are needed?
Thanks for a reply ASAP
Ads By Google
Related Models
Whirlpool LSQ9030PQ0 Automatic Washer
Whirlpool LSQ9030PQ1 Automatic Washer
Whirlpool LSQ9030PQ2 Automatic Washer
Whirlpool LSQ9030PQ4 Automatic Washer
Whirlpool LSQ9030PQ5 Automatic Washer
Whirlpool LSQ9110KQ0
Whirlpool LSQ9110KQ1
Whirlpool LSQ9110LG0
Whirlpool LSQ9110LG1 Automatic Washer
Whirlpool LSQ9110LW0
Whirlpool LSQ9110LW1 Automatic Washer
Whirlpool LSQ9110PW0 Automatic Washer
Whirlpool LSQ9110PW1 Automatic Washer
Whirlpool LSQ9110PW2 Automatic Washer
Whirlpool LSQ9110PW3 Automatic Washer
Whirlpool LSQ9110PW4 Automatic Washer
Whirlpool LSQ9200KQ0
Whirlpool LSQ9200KT0
Whirlpool LSQ9200LQ0
Whirlpool LSQ9200LQ1 Automatic Washer
Whirlpool LSQ9200LQ2 Automatic Washer
Whirlpool LSQ9200LQ3 Automatic Washer
Whirlpool LSQ9200LT0
Whirlpool LSQ9200LT1 Automatic Washer
Whirlpool LSQ9200LT2 Automatic Washer
Whirlpool LSQ9200LT3 Automatic Washer
Whirlpool LSQ9200PQ0 Automatic Washer
Whirlpool LSQ9200PQ1 Automatic Washer
Whirlpool LSQ9200PQ3 Automatic Washer
Whirlpool LSQ9200PQ4 Automatic Washer
Whirlpool LSQ9200PT0 Automatic Washer
Whirlpool LSQ9200PT1 Automatic Washer
Whirlpool LSQ9200PT3 Automatic Washer
Whirlpool LSQ9200PT4 Automatic Washer
Whirlpool LSQ9210HQ0
Whirlpool LSQ9210HZ0
Whirlpool LSQ9211KQ0
Whirlpool LSQ9211KQ1
Whirlpool LSQ9211KT0
Whirlpool LSQ9211KT1
Whirlpool LSQ9244EQ0
Whirlpool LSQ9244EZ0
Whirlpool LSQ9264HQ0
Whirlpool LSQ9264HZ0
Whirlpool LSQ9500LQ0
Whirlpool LSQ9500LT0
Whirlpool LSQ9510JQ0
Whirlpool LSQ9510JQ1
Whirlpool LSQ9510LQ0
Whirlpool LSQ9510LT0
Whirlpool LSQ9520LQ0
Whirlpool LSQ9520LT0
Whirlpool LSQ9544KQ0
Whirlpool LSQ9544KT0
Whirlpool LSQ9549LG0
Whirlpool LSQ9549LG1 Automatic Washer
Whirlpool LSQ9549LG2 Automatic Washer
Whirlpool LSQ9549LG3 Automatic Washer
Whirlpool LSQ9549LQ0
Whirlpool LSQ9549LQ1 Automatic Washer
Whirlpool LSQ9549LQ2 Automatic Washer
Whirlpool LSQ9549LQ3 Automatic Washer
Whirlpool LSQ9549LW0
Whirlpool LSQ9549LW1 Automatic Washer
Whirlpool LSQ9549LW2 Automatic Washer
Whirlpool LSQ9549LW3 Automatic Washer
Whirlpool LSQ9549PG0 Automatic Washer
Whirlpool LSQ9549PG1 Automatic Washer
Whirlpool LSQ9549PG2 Automatic Washer
Whirlpool LSQ9549PG3 Automatic Washer
Whirlpool LSQ9549PG5 Automatic Washer
Whirlpool LSQ9549PG6 Automatic Washer
Whirlpool LSQ9549PW0 Automatic Washer
Whirlpool LSQ9549PW1 Automatic Washer
Whirlpool LSQ9549PW2 Automatic Washer
Whirlpool LSQ9549PW3 Automatic Washer
Whirlpool LSQ9549PW5 Automatic Washer
Whirlpool LSQ9549PW6 Automatic Washer
Whirlpool LSQ9550PW0 Automatic Washer
Whirlpool LSQ9550PW1 Automatic Washer
Whirlpool LSQ9550PW2 Automatic Washer
Whirlpool LSQ9550PW3 Automatic Washer
Whirlpool LSQ9550PW4 Automatic Washer
Whirlpool LSQ9560PW0 Automatic Washer
Whirlpool LSQ9560PW1 Automatic Washer
Whirlpool LSQ9560PW3 Automatic Washer
Whirlpool LSQ9560PW4 Automatic Washer
Whirlpool LSQ9564JQ0
Whirlpool LSQ9564JQ1
Whirlpool LSQ9564JT0
Whirlpool LSQ9564JT1
Whirlpool LSQ9564JZ0
Whirlpool LSQ9564MQ0 Automatic Washer
Whirlpool LSQ9600JQ0
Whirlpool LSQ9600JQ1
Whirlpool LSQ9600JT0
Whirlpool LSQ9600JT1
Whirlpool LSQ9600LG0
Whirlpool LSQ9600LG1 Automatic Washer
Whirlpool LSQ9600LW0
Whirlpool LSQ9600LW1 Automatic Washer
Whirlpool LSQ9610JQ0
Whirlpool LSQ9610JQ1
Whirlpool LSQ9610JT0
Whirlpool LSQ9610JT1
Whirlpool LSQ9610LG0 Automatic Washer
Whirlpool LSQ9610LW0 Automatic Washer
Whirlpool LSQ9620LG0
Whirlpool LSQ9620LG1 Automatic Washer
Whirlpool LSQ9620LW0
Whirlpool LSQ9620LW1 Automatic Washer
Whirlpool LSQ9645KQ0
Whirlpool LSQ9645KQ1
Whirlpool LSQ9645KT0
Whirlpool LSQ9645KT1
Whirlpool LSQ9650PG0 Automatic Washer
Whirlpool LSQ9650PG1 Automatic Washer
Whirlpool LSQ9650PG2 Automatic Washer
Whirlpool LSQ9650PG3 Automatic Washer
Whirlpool LSQ9650PG4 Automatic Washer
  #2 (permalink)
Old 08-17-2011, 03:10 PM
Member
dnlow is on a distinguished road
Default
Sounds like the common lid switch problem for this type of washer. Can you here a click when the lid is closed? Depending on what type you need should be a $20 to $25 part. I would search the internet for something like " how to replace lid switch Whirlpool washer". You should find many videos on how to do this very simple repair.
  #3 (permalink)
Old 08-18-2011, 07:01 AM
Junior Member
Default Whirlpool washer: not spinning
Thank you for such a quick reply.
But wouldn't the lid switch also affect other cycles,too? Those appear to be working correctly.
Yes, I do hear a click when I close the door. Is that good or bad?
  #4 (permalink)
Old 08-18-2011, 08:53 AM
Member
Default
Sorry I miss read the whole paragraph. Lid switch seems good. I would think the problem is with the brakes or the clutch. Again a search of the internet will prove helpful in determining exactly what is the problem.
  #5 (permalink)
Old 08-18-2011, 02:04 PM
Junior Member
Thank you for the clarification. I hope it's not too difficult to check the brake and or clutch so the problem can be corrected quickly.
  #6 (permalink)
Old 08-22-2011, 09:03 AM
Junior Member
Model: LSQ9030PQ1
Solution: Replace the clutch
If all the other functions are working properly, but it’s not spinning, replacing the clutch may be the solution.
The clutch repair kit contained all the replacement parts; but all may not be needed as was our case. Since our plastic drive cam was in good condition we did not use the new one. So that was one less part to remove and saved time.
As with most jobs, “many hands make light work.” And you’ll need a helper for this job. While the machine’s apart, take the time to clean any dust & dirt especially on the motor. We took the motor outside & used an air compressor to blow all the dust out. Upon reassembly, the washer performed perfectly. The spin function was fast & smooth as it should be. The clothes took much less time to dry.
Appliance Parts Pros diagrams helped but there wasn’t any video for clutch repair. Since the performance of the clutch is necessary for the cycles to work efficiently, a video would be a big help to DIYers.
The technical support on the Repair Forum was surprisingly quick: less than 24 hrs. However, speaking with a technician would have been quicker. Regardless,
we will definitely use this site again.
Thank you dnlow.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Washer has trouble spinning thomasc Washer Repair 1 10-25-2010 09:40 AM
Whirlpool Washer not spinning A1adventures Washer Repair 1 10-31-2009 06:41 AM
Whirlpool Washer Wobbles when spinning valboynton58 Washer Repair 1 08-08-2009 03:47 PM
whirlpool washer has trouble spinning ploose@omnek.com Washer Repair 1 03-06-2009 08:11 PM
Whirlpool Washer humming but not spinning hillaholic Washer Repair 1 10-31-2008 10:34 AM
