Discuss
admiral washer
 in
Washer Repair
Washer tub makes a rubbing sound when agitating. It seems to work fine on light loads, but makes a rubbing
Appliance Repair Forum > Appliance Repair Help > Washer Repair » admiral washer
  #1 (permalink)
Old 11-25-2007, 01:38 PM
margsain margsain is offline
Junior Member
margsain is on a distinguished road
Default admiral washer
Model Number: AAV7000AWW   Brand: Admiral   Age: 1 - 5 years
Washer tub makes a rubbing sound when agitating. It seems to work fine on light loads, but makes a rubbing sound like the tub is sitting on something rubber.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-26-2007, 01:31 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the pump bearing.
Lift the washer up from the front, remove the belt and check how the pump pulley is moving. If you see any tension or noises, replace the pump.
If this is not the issue, remove the front panel and check for the water leak through the central seal.
- The part number for the pump AP3873289
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-26-2007, 07:16 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
Take the front off the cabinet, look at the bottom at the base. you will see a snubber ring on the base, there will be dust and soap scum under it,try to clean under the ring, then spray some silicone under the ring,and see if that works.
__________________
  #4 (permalink)
Old 09-05-2008, 01:35 PM
kornkob1 kornkob1 is offline
Junior Member
kornkob1 is on a distinguished road
Question
Quote:
when i push down on the agitater the noise goes away
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
capacity plus admiral dryer broken_dryer_forthuachuca Dryer Repair 0 11-19-2007 06:43 PM
Admiral oven door repair pfaffy Oven Repair (including Ranges and Cooktops) 1 11-02-2007 02:49 PM
how do i replace a belt on an Admiral Dryer pookie Dryer Repair 3 10-11-2007 05:07 AM
Admiral Refrigerator yazooms37342 Refrigerator & Freezer Repair 1 08-10-2007 12:40 PM
admiral capacity plus jcwilson Washer Repair 1 07-30-2007 06:42 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
