Discuss
Washer Not Spinning All Water Out
 in
Washer Repair
I Have A Maytag Stacked Unit, My Washer Isn't Spinning All The Water Out, It's Leaving About An Inch Or
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Not Spinning All Water Out
  #1 (permalink)
Old 08-16-2011, 05:46 PM
Junior Member
HONEYBUN is on a distinguished road
Default Washer Not Spinning All Water Out
Model Number: LS7806   Brand: Maytag   Age: 5 - 10 years
I Have A Maytag Stacked Unit, My Washer Isn't Spinning All The Water Out, It's Leaving About An Inch Or Two And The Clothes Are Not Spun Dry.........help!
Related Models
Whirlpool LSB6000LQ0 WASHER
Whirlpool LSB6000PQ0 AUTOMATIC WASHER
Whirlpool LSB6000PQ1 AUTOMATIC WASHER
Whirlpool LSB6000PQ2 AUTOMATIC WASHER
Whirlpool LSB6200KQ0 WASHER
Whirlpool LSB6200KQ1 AUTOMATIC WASHER
Whirlpool LSB6200PQ0 AUTOMATIC WASHER
Whirlpool LSB6200PQ1 AUTOMATIC WASHER
Whirlpool LSB6200PQ2 AUTOMATIC WASHER
Whirlpool LSB6300LQ0 WASHER - DIRECT DRIVE
Whirlpool LSB6300LW0 WASHER - DIRECT DRIVE
Whirlpool LSB6300LW1 AUTOMATIC WASHER
Whirlpool LSB6300LW2 AUTOMATIC WASHER
Whirlpool LSB6300LW3 AUTOMATIC WASHER
Whirlpool LSB6300PW0 AUTOMATIC WASHER
Whirlpool LSB6300PW1 AUTOMATIC WASHER
Whirlpool LSB6300PW3 AUTOMATIC WASHER
Whirlpool LSB6300PW4 AUTOMATIC WASHER
Whirlpool LSB6400KQ0 WASHER
Whirlpool LSB6400KQ1 WASHER
Whirlpool LSB6400LW0 WASHER - DIRECT DRIVE
Whirlpool LSB6400LW1 AUTOMATIC WASHER
Whirlpool LSB6500PW0 AUTOMATIC WASHER
Whirlpool LSB6500PW1 AUTOMATIC WASHER
Whirlpool LSB6500PW2 AUTOMATIC WASHER
Whirlpool LSB6500PW3 AUTOMATIC WASHER
Whirlpool LSB6500PW4 AUTOMATIC WASHER
 LSC21943ST Refrigerator
 LSC26905SB Refrigerator
 LSC26905SW Refrigerator
 LSC26905TT Refrigerator
 LSC26945SW Refrigerator
 LSC26945TT Refrigerator
 LSC27910SB Refrigerator
 LSC27910ST Refrigerator
 LSC27910SW Refrigerator
 LSC27910TT Refrigerator
 LSC27926SB Refrigerator
 LSC27926ST Refrigerator
 LSC27926SW Refrigerator
 LSC27926TT Refrigerator
 LSC27931SB Refrigerator
 LSC27931ST Refrigerator
 LSC27931SW Refrigerator
 LSC27950SB Refrigerator
 LSC27950ST Refrigerator
 LSC27950SW Refrigerator
 LSC27970ST Refrigerator
 LSC27990TT Refrigerator
 LSC27991TT Refrigerator
Whirlpool LSC5000PQ0 AUTOMATIC WASHER
Whirlpool LSC5000PQ1 AUTOMATIC WASHER
Whirlpool LSC5000PQ2 AUTOMATIC WASHER
Whirlpool LSC6244AW0 Washers*
Whirlpool LSC6244BQ0 Washers*
Whirlpool LSC6244BW0 Washers*
Whirlpool LSC8244BG0 AUTOMATIC WASHER
Whirlpool LSC8244BG1 AUTOMATIC WASHER
Whirlpool LSC8244BN0 AUTOMATIC WASHER
Whirlpool LSC8244BN1 AUTOMATIC WASHER
Whirlpool LSC8244BQ0 AUTOMATIC WASHER
Whirlpool LSC8244BQ1 AUTOMATIC WASHER
Whirlpool LSC8244BW0 AUTOMATIC WASHER
Whirlpool LSC8244BW1 AUTOMATIC WASHER
Whirlpool LSC8244BZ0 AUTOMATIC WASHER
Whirlpool LSC8244BZ1 AUTOMATIC WASHER
Whirlpool LSC8244DQ0 AUTOMATIC WASHER
Whirlpool LSC8244DZ0 AUTOMATIC WASHER
Whirlpool LSC8244EQ0 WASHER
Whirlpool LSC8244EQ1 WASHER
Whirlpool LSC8244EZ0 WASHER
Whirlpool LSC8244EZ1 WASHER
Whirlpool LSC8245AN0 AUTOMATIC WASHER
Whirlpool LSC8245AQ0 AUTOMATIC WASHER
Whirlpool LSC8245AW0 Washers*
Whirlpool LSC8245BW0 Washers*
Whirlpool LSC9000PW0 AUTOMATIC WASHER
Whirlpool LSC9000PW1 AUTOMATIC WASHER
Whirlpool LSC9000PW2 AUTOMATIC WASHER
Whirlpool LSC9245BN0 AUTOMATIC WASHER
Whirlpool LSC9245BN1 AUTOMATIC WASHER
Whirlpool LSC9245BQ0 AUTOMATIC WASHER
Whirlpool LSC9245BQ1 AUTOMATIC WASHER
Whirlpool LSC9245BW0 AUTOMATIC WASHER
Whirlpool LSC9245BW1 AUTOMATIC WASHER
Whirlpool LSC9245BZ0 AUTOMATIC WASHER
Whirlpool LSC9245BZ1 AUTOMATIC WASHER
Whirlpool LSC9355AG0 AUTOMATIC WASHER
Whirlpool LSC9355AN0 AUTOMATIC WASHER
Whirlpool LSC9355AW0 Washers*
Whirlpool LSC9355BN0 AUTOMATIC WASHER
Whirlpool LSC9355BN1 AUTOMATIC WASHER
Whirlpool LSC9355BQ0 AUTOMATIC WASHER
Whirlpool LSC9355BQ1 AUTOMATIC WASHER
Whirlpool LSC9355BW0 AUTOMATIC WASHER
Whirlpool LSC9355BW1 AUTOMATIC WASHER
Whirlpool LSC9355BZ0 AUTOMATIC WASHER
Whirlpool LSC9355BZ1 AUTOMATIC WASHER
Whirlpool LSC9355DQ0 AUTOMATIC WASHER
Whirlpool LSC9355DZ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ1 DIRECT-DRIVE WASHER
Whirlpool LSC9355EZ0 AUTOMATIC WASHER
Whirlpool LSC9355EZ1 DIRECT-DRIVE WASHER
Admiral LSD2615HEB REF - SXS/I&W
Admiral LSD2615HEW REF - SXS/I&W
Admiral LSD2615HEZ REF - SXS/I&W
Maytag LSE1000 STACKED LAUNDRY- ELE
Maytag LSE1000T Stacked Laundry - Ele
Jenn-Air LSE2700W STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-8 STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-C STACKED LAUNDRY- ELE
Jenn-Air LSE2704W STACKED LAUNDRY- ELE
Jenn-Air LSE2704W-8 STACKED LAUNDRY- ELE
Maytag LSE7800 STACKED LAUNDRY- ELE
Maytag LSE7800ACE STACKED LAUNDRY- ELE
Maytag LSE7800ACL STACKED LAUNDRY- ELE
Maytag LSE7800ACW STACKED LAUNDRY- ELE
Maytag LSE7800ADE STACKED LAUNDRY- ELE
Maytag LSE7800ADL STACKED LAUNDRY- ELE
  #2 (permalink)
Old 08-18-2011, 06:23 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
If water is staying in the tub it suggests you have a problem with an injured pump, or more likely, some obstruction in the drain line to the pump, or from the pump to the drain pipe.
__________________
  #3 (permalink)
Old 08-20-2011, 06:02 AM
Junior Member
Default
Quote:
The drain line is clear to pump & from pump to drain pipe, we took off the pump & ran water through it, it looks fine, is there a filter somewhere that may be clogged?
  #4 (permalink)
Old 08-20-2011, 08:06 AM
Senior Expert
APP Volunteer
Default
If the drain lines are clear then I have to think the pump is the problem evenif you cannot see a problem.
There is no filter to block things, but backflush into the tub with a hose to make sure nothing is in there where you cannot see it.
__________________
  #5 (permalink)
Old 08-20-2011, 02:18 PM
Junior Member
Default
Ok, did that and still nothing, and I can't run this thing through an extra spin cycle & get the water out, it just won't come out............I have to wring out the clothes & dip the water out with a cup and start the next load...........ugh.
  #6 (permalink)
Old 08-20-2011, 05:58 PM
Senior Expert
APP Volunteer
Default
I think at this point you should go ahead and replace the pump. If the pump is running and it is not defective and the drain hoses are not blocked it must drain.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer problems with pumping water out and spinning alfredt Washer Repair 1 01-30-2011 11:49 AM
Washer is not spinning water out of load ptlaatsch Washer Repair 0 09-16-2010 06:04 PM
Washer not spinning all the water out of clothes Chil Washer Repair 1 04-07-2010 05:45 PM
Washer not spinning the water out Gabesrepair Washer Repair 0 03-06-2009 05:13 PM
Agitator not spinning and washer leaking water hoss00912 Washer Repair 0 07-10-2008 08:51 AM
