Discuss
Leaking Washer On The First Spin Cycle
 in
Washer Repair
The washer (Maytag LSG1000 stack washer/dryer///bought in 1990)leakes in the back left side of the back area of the tub
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Leaking Washer On The First Spin Cycle
  #1 (permalink)
Old 04-01-2009, 01:57 PM
Junior Member
SKYHAWK1 is on a distinguished road
Red face Leaking Washer On The First Spin Cycle
Model Number: LSG1000   Brand: Maytag   Age: More than 10 years
The washer (Maytag LSG1000 stack washer/dryer///bought in 1990)leakes in the back left side of the back area of the tub it seems and possibly the upper left part also or only.I can't see any leaks at the hoses and connections on the left side.I replaced the Injector valve (part # AP4025626) and the Nozzle(part # AP (40255333).It seems like a hose or connection of some sort that feeds the rinse water in is the problem.Its very tough not seeing behind the tub.The water leaks down on the left bottom and also sprays on the bottom back panel over the vents and on the middle left side inside panel.I hope you can help me.....Thank You
Ads By Google
Related Models
Maytag LSG1000 Stacked Laundry - Gas
Maytag LSG1000T Stacked Laundry - Gas
Jenn-Air LSG2700W Stacked Laundry - Gas
Jenn-Air LSG2704W Stacked Laundry - Gas
Maytag LSG7800 Stacked Laundry - Gas
Maytag LSG7800AAE Stacked Laundry - Gas
Maytag LSG7800AAL Stacked Laundry - Gas
Maytag LSG7800AAW Stacked Laundry - Gas
Maytag LSG7800ABE Stacked Laundry - Gas
Maytag LSG7800ABL Stacked Laundry - Gas
Maytag LSG7800ABW Stacked Laundry - Gas
Maytag LSG7804AAE Stacked Laundry - Gas
Maytag LSG7804AAL Stacked Laundry - Gas
Maytag LSG7804AAM Stacked Laundry - Gas
Maytag LSG7804ABE Stacked Laundry - Gas
Maytag LSG7804ABL Stacked Laundry - Gas
Maytag LSG7804ABM Stacked Laundry - Gas
Maytag LSG7806AAE Stacked Laundry - Gas
Maytag LSG7806AAM Stacked Laundry - Gas
Maytag LSG7806AAQ Stacked Laundry - Gas
Maytag LSG7806ABE Stacked Laundry - Gas
Maytag LSG7806ABM Stacked Laundry - Gas
Maytag LSG7806ABQ Stacked Laundry - Gas
Maytag LSG9900 Stacked Laundry - Gas
Maytag LSG9900AAE Stacked Laundry - Gas
Maytag LSG9900AAL Stacked Laundry - Gas
Maytag LSG9900AAW Stacked Laundry - Gas
Maytag LSG9900ABE Stacked Laundry - Gas
Maytag LSG9900ABL Stacked Laundry - Gas
Maytag LSG9900ABW Stacked Laundry - Gas
Maytag LSG9904AAE Stacked Laundry - Gas
Maytag LSG9904AAL Stacked Laundry - Gas
Maytag LSG9904AAM Stacked Laundry - Gas
Whirlpool LSH9264HQ0
Whirlpool LSL9244EQ0
Whirlpool LSL9244EZ0
Whirlpool LSL9345EQ0
Whirlpool LSL9345EQ1
Whirlpool LSL9345EZ0
Whirlpool LSL9345EZ1
Whirlpool LSL9355DQ0
Whirlpool LSL9355EQ0
Whirlpool LSL9355EQ1
Whirlpool LSN1000HQ0
Whirlpool LSN1000HZ0
Whirlpool LSN1000JQ0
Whirlpool LSN1000JQ1
Whirlpool LSN1000JT0
Whirlpool LSN1000JT1
Whirlpool LSN1000KQ0
Whirlpool LSN1000KT0
Whirlpool LSN1000LG0
Whirlpool LSN1000LG1 Automatic Washer
Whirlpool LSN1000LG2 Automatic Washer
Whirlpool LSN1000LG3 Automatic Washer
Whirlpool LSN1000LW0
Whirlpool LSN1000LW1 Automatic Washer
Whirlpool LSN1000LW2 Automatic Washer
Whirlpool LSN1000LW3 Automatic Washer
Whirlpool LSN1000PQ0 Automatic Washer
Whirlpool LSN1000PQ1 Automatic Washer
Whirlpool LSN1000PQ2 Automatic Washer
Whirlpool LSN1000PQ3 Automatic Washer
Whirlpool LSN2000JQ0
Whirlpool LSN2000JQ1
Whirlpool LSN2000JQ2
Whirlpool LSN2000JT0
Whirlpool LSN2000JT1
Whirlpool LSN2000JT2
Whirlpool LSN2000LG0
Whirlpool LSN2000LG1 Automatic Washer
Whirlpool LSN2000LW0
Whirlpool LSN2000LW1 Automatic Washer
Whirlpool LSN2000PG0 Automatic Washer
Whirlpool LSN2000PG1 Automatic Washer
Whirlpool LSN2000PG2 Automatic Washer
Whirlpool LSN2000PG3 Automatic Washer
Whirlpool LSN2000PG4 Automatic Washer
Whirlpool LSN2000PW0 Automatic Washer
Whirlpool LSN2000PW1 Automatic Washer
Whirlpool LSN2000PW2 Automatic Washer
Whirlpool LSN2000PW3 Automatic Washer
Whirlpool LSN2000PW4 Automatic Washer
Whirlpool LSN3000PG0 Automatic Washer
Whirlpool LSN3000PG1 Automatic Washer
Whirlpool LSN3000PG2 Automatic Washer
Whirlpool LSN3000PG3 Automatic Washer
Whirlpool LSN3000PG4 Automatic Washer
Whirlpool LSN3000PW0 Automatic Washer
Whirlpool LSN3000PW1 Automatic Washer
Whirlpool LSN3000PW2 Automatic Washer
Whirlpool LSN3000PW3 Automatic Washer
Whirlpool LSN3000PW4 Automatic Washer
Whirlpool LSN7233BN0
Whirlpool LSN7233BN1
Whirlpool LSN7233BQ0
Whirlpool LSN7233BQ1
Whirlpool LSN7233BW0
Whirlpool LSN7233BW1
Whirlpool LSN7233DQ0
Whirlpool LSN7233DW0
Whirlpool LSN8244AN0
Whirlpool LSN8244AQ0
Whirlpool LSN8244AW0
Whirlpool LSN8244BN0
Whirlpool LSN8244BQ0
Whirlpool LSN8244BW0
Whirlpool LSP6244AG0
Whirlpool LSP6244AN0
Whirlpool LSP6244AW0
Whirlpool LSP6244BG0
Whirlpool LSP6244BN0
Whirlpool LSP6244BW0
Whirlpool LSP8244BG0
Whirlpool LSP8244BG1
Whirlpool LSP8244BN0
Whirlpool LSP8244BN1
Whirlpool LSP8244BW0
Whirlpool LSP8244BW1
Whirlpool LSP8245AN0
  #2 (permalink)
Old 05-11-2009, 01:31 PM
Junior Member
Smile Maytag Lsg1000
I had the repairman try to fix it and he said it was the inner tub.I'm not so sure of this.He did level off the unit which helped abit.The washer doesn't leak when using a "small" load but still leaks alot in the "medium" and "large" load options for wash.I put in the injector nozzle plus the rubber tube which the injector nozzle goes into.I noticed that the small,medium, and large water level options aren't almost all the same as before.You can notice less water in the small load than before. The water comes into the tub about at the same rate but more water drips in on the left upper tub toop inner rim area for the fill as it once did.I'm thinking that the problem is in this area and it might be the injector hose that feeds into the tub. Another thought is the washer pump which appears to be working fine though.Somehow on the medium and large loads modes the water isn't getting out fast enough on the spin cycle and leaks.The tub spins nice and pretty smooth which makes me think the inner tub and transmision are ok.the belts are new and the stem and bearings were repaired by the same repairman who did a good job and knows this machine pretty well for the most part.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag top loading washer leaking in spin cycle from bottom kleve Washer Repair 3 07-23-2009 11:12 AM
Maytag leaking during spin cycle red574 Washer Repair 2 04-25-2009 03:04 PM
GE model WJRE5500GWW leaking under washer during spin cycle... aries47 Washer Repair 0 03-03-2009 11:26 AM
Leaking on Spin cycle albee101 Washer Repair 0 08-04-2008 11:13 AM
Leaking washer during spin cycle Greg Mitchell Washer Repair 2 02-29-2008 04:06 AM
