| » GE Front loader won't spin |
Model Number: WBVH6240FWW Brand: GE Age: 1 - 5 years
Hello everyone,
I have a WBVH6240FWW, and of course, similar issues to everyone else's problems, my washing machine decided to stop spinning. I have reset the control board, run through the self tests: t01 - reset to #3 t02 - error code E54 only t03 - cod 100, EE 13, inv 143 t04 - run through cycle 012, 123, 234, 345, 456, 567, 678, 789, 890 (all seemed to work) t05 - displayed P and ran for about 1 min, then return to t05 t06 - ran to all levels and emptied, seemed fine t07 - I did not perform t08 - I did not perform t09 - I did not peform t10 - displays tt, does nothing, did not see any 120v reading at blue/red pins to inverter t11 - shows 0, does nothing, no 120V at inverter t12 - I did not perform t13 - I did not perform t14 - shows 0, does nothing, no 120V at inverter I did check the motor resistance and shows 6 ohms across the three wire combinations, and sensor checks okay at 118 ohms. The only time I see 120V go to the red/blue input supply to the inverter is when I have the unit in normal run operation, start a wash cycle, the door will lock, unlock, lock, then the input to the inverter will slow ramp to about 112 V, then stop, then slow ramp again to about 112V, then stop, the drum will jerk slightly, and the unit will drain and stop working (flashing light on Start/Pause button). I'm not sure if this leads to a bad inverter, or a bad control board output to the inverter. With a house of a wife and 3 daughters I need to make sure laundry can be done. Any help is appreciated! Thanks. Read more: GE Front Load Washer won't tumble/spin http://forum.appliancepartspros.com Ads By Google Related Models |
| Display Modes | |
| front loader won't spin | ezr vinh | Washer Repair | 0 | 03-06-2011 02:36 PM |
| Front loader won't spin | msappington | Washer Repair | 1 | 03-21-2010 11:39 AM |
| Frigidaire front loader won't spin | brianb630 | Washer Repair | 3 | 01-20-2010 01:56 AM |
| front loader will not final spin | gillpx | Washer Repair | 3 | 08-04-2008 05:44 AM |
| Front-loader won't spin, only some tumble | Flamingstar | Washer Repair | 0 | 01-26-2008 04:04 PM |
