GE Front Load Washer Gets Stuck in Cycle - Error Code E22
Washer Repair
The problem is that the washer seems to stop towards the end of the normal cycle (normally around the 20
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Front Load Washer Gets Stuck in Cycle - Error Code E22
  #1 (permalink)
Old 08-14-2011, 05:44 PM
Junior Member
loganer is on a distinguished road
Question GE Front Load Washer Gets Stuck in Cycle - Error Code E22
Model Number: WBVH6240FWW   Brand: GE   Age: 1 - 5 years
The problem is that the washer seems to stop towards the end of the normal cycle (normally around the 20 min. remaining mark). It gets stuck every time on both hot and cold cycles. The only thing that works from there is to run the Drain & Spin Cycle.
My trouble shooting so far has been:
  1. Cleaned water filter & inspected pump - All clear.
  2. Ran diagnostic mode and found error code E22. That was the only error code listed.
  3. Successfully completed T06. There was a problem during T06 where the drain line created a suction because I had pushed it down too far inside the pipe in the wall. I trimmed it to 3" and the siphon stopped, and T06 completed successfully.
  4. I then ran test modes T08 and T09. T08 (hot) completed very well. The whole test was done in about 2 min. The water filled up quickly and pumped out quickly. T09 didn't go well. The water filled up slowly and never pumped out. The display was stuck reading "CLD" and the test normally timed out after 30 min.
  5. Based on that, I thought there might be a problem with the cold water supply. I verified that both supply hoses were clear and flowing well. The screen inlets also look good on both supply lines. I checked the resistance across the solenoid and both hot and cold water valves read a very similar number (about 2,000 ohms).
  6. I then re-ran tests T08 and T09 with the hoses unconnected and verified that a voltage was being supply to the solenoid valve and I successfully read a voltage reading on both the hot and cold valves.
  7. I'm somewhat stuck on what to do from here. Everything that I've read, says to replace the solenoid valve, but it appears to be fully functional from my measurements. Before I spend $50 and replace the valve, does anyone have any ideas on other things to try first or a better method of trouble shooting the solenoid valve?
Related Models
General Electric WBVH6240H0WW Washer
General Electric WBVH6240H1WW WASHER
General Electric WBXE2070A0AA Washer
General Electric WBXE2070A0WW Washer
General Electric WBXE2070A2WW Washer
General Electric WBXR1060T2AA Washer
General Electric WBXR1060T2WW Washer
General Electric WBXR1060T3AA Washer
General Electric WBXR1060T3WW Washer
General Electric WBXR1060T4AA Washer
General Electric WBXR1060T4WW Washer
General Electric WBXR1060T5AA Washer
General Electric WBXR1060T5WW Washer
General Electric WBXR1060T8AA Washer
General Electric WBXR1060T8WW Washer
General Electric WBXR1060TAAA Washer
General Electric WBXR1060TAWW Washer
General Electric WBXR1060TBAA Washer
General Electric WBXR1060TBWW Washer
General Electric WBXR1090A0AA Washer
General Electric WBXR1090A0WW Washer
General Electric WBXR1090A1AA Washer
General Electric WBXR1090A1WW Washer
General Electric WBXR1090A2AA Washer
General Electric WBXR1090A2WW Washer
General Electric WBXR2060V0AA Washer
General Electric WBXR2060V0WW Washer
General Electric WBXR2060V1AA Washer
General Electric WBXR2060V1WW Washer
General Electric WBXR2060V2AA Washer
General Electric WBXR2060V2WW Washer
General Electric WBXR2090B0CC Washer
General Electric WBXR2090B0WW Washer
General Electric WBXR2090B3WW Washer
General Electric WBXR2090B4WW Washer
General Electric WBXR2090D0WW Washer
General Electric WBXR2090D2WW Washer
General Electric WBXR2090D5WW Washer
General Electric WBXR2090DAWW Washer
General Electric WBXR3100B0WW Washer
General Electric WBXR3100B3WW Washer
Frigidaire WC2MA1 Frg(v1) / Washer
Frigidaire WC2MF1 Frg(v2) / Washer
Frigidaire WC2MH1 Frg(v3) / Washer
Frigidaire WC2ML1 Frg(v4) / Washer
Frigidaire WC2ML2 Frg(v1) / Washer
Frigidaire WC2MW1 Frg(v5) / Washer
Frigidaire WC2MW2 Frg(v2) / Washer
Frigidaire WC3MA1 Frg(v6) / Washer
Frigidaire WC3MA2 Frg(v7) / Washer
Frigidaire WC3MF1 Frg(v8) / Washer
Frigidaire WC3MF2 Frg(v9) / Washer
Frigidaire WC3MH1 Frg(v10) / Washer
Frigidaire WC3MH2 Frg(v11) / Washer
Frigidaire WC3MH3 Frg(v3) / Washer
Frigidaire WC3ML1 Frg(v12) / Washer
Frigidaire WC3ML2 Frg(v13) / Washer
Frigidaire WC3ML3 Frg(v4) / Washer
Frigidaire WC3MW1 Frg(v14) / Washer
Frigidaire WC3MW2 Frg(v15) / Washer
Frigidaire WC3MW3 Frg(v5) / Washer
Frigidaire WC4MA1 Frg(v16) / Washer
Frigidaire WC4MF1 Frg(v17) / Washer
Frigidaire WC4MH1 Frg(v18) / Washer
Frigidaire WC4ML1 Frg(v19) / Washer
Frigidaire WC4ML2 Frg(v6) / Washer
Frigidaire WC4MW1 Frg(v20) / Washer
Frigidaire WC4MW2 Frg(v7) / Washer
Frigidaire WC7DL2 Frg(v1) / Top Loading Washer
Frigidaire WC7DL3 Frg(v8) / Top Load Washer
Frigidaire WC7DW2 Frg(v2) / Top Loading Washer
Frigidaire WC7DW3 Frg(v7) / Top Load Washer
Frigidaire WC8DH2 Frg(v3) / Top Loading Washer
Frigidaire WC8DH3 Frg(v9) / Top Load Washer
Frigidaire WC8DL2 Frg(v4) / Top Loading Washer
Frigidaire WC8DL3 Frg(v8) / Top Load Washer
Frigidaire WC8DW2 Frg(v5) / Top Loading Washer
Frigidaire WC8DW3 Frg(v7) / Top Load Washer
Frigidaire WC9DL3 Frg(v11) / Top Loading Washer
Frigidaire WC9DW3 Frg(v10) / Top Loading Washer
General Electric WCCB1030B0KC Washer
General Electric WCCB1030B0WC Washer
General Electric WCCB1030B1KC Washer
General Electric WCCB1030B1WC Washer
General Electric WCCB1030B1WW Washer
General Electric WCCB1030B2KC Washer
General Electric WCCB1030B2WC Washer
General Electric WCCB1030B2WW Washer
General Electric WCCB1030D0KC Washer
General Electric WCCB1030D0WC Washer
General Electric WCCB1030D1KC Washer
General Electric WCCB1030D1WC Washer
General Electric WCCB1030F2WC Washer
General Electric WCCB1030F3WC Washer
General Electric WCCB1030H0WC WASHER
General Electric WCCB1030H1WC WASHER
General Electric WCCB1030H2WC WASHER
General Electric WCCB1030H3WC WASHER
General Electric WCCB1030H4WC WASHER
General Electric WCCB1030H5WC WASHER
General Electric WCCB1030H6WC COIN-OP WASHER
General Electric WCCB1030J0WC COIN-OP WASHER
General Electric WCCB1030J1WC COIN-OP WASHER
General Electric WCCB1030T2AC Washer
General Electric WCCB1030T2WC Washer
General Electric WCCB1030T4AC Washer
General Electric WCCB1030T4WC Washer
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
General Electric Front load washer stuck in drain cycle Jasonkmol Washer Repair 5 05-07-2012 09:53 AM
Frigidaire Front Load Waher will not spin - error code E46 JimRock Washer Repair 2 08-11-2011 05:23 PM
front load washer f3 error code bo_okie1 Washer Repair 3 07-15-2011 08:34 AM
Front Load Maytag What is Error Code f06 mbippus Washer Repair 1 08-28-2008 04:17 PM
Front Load Washer Door Stuck GlennaA Washer Repair 1 07-11-2008 06:52 PM
