Discuss
Replacement of Tub Bearing
 in
Washer Repair
Help! I need to replace a tub bearing on my maytag washer. The reason I am replacing it is because
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Replacement of Tub Bearing
  #1 (permalink)
Old 03-31-2009, 03:01 PM
Junior Member
Augie is on a distinguished road
Wink Replacement of Tub Bearing
Model Number: LAT9706AAE   Brand: Maytag   Age: 5 - 10 years
Help!
I need to replace a tub bearing on my maytag washer. The reason I am replacing it is because there is a small leak in this area. I am having problems removing the steel portion of the existing tub bearing from the shaft of the transmission. (this is not the cooper colored bearing with the rubber ring). Is there an easy trick to this? I tried to remove it but dont want to destroy it or the transmission. This part of the existing bearing is worn and has some rust on it. I think this needs tobe replace if possible. It also appears that this part of the bearing is molded onto the transmission.
Also, when reassembling the washing machine is there any greasing that I should do. Other tips would be helpful.
Thanks,
Augie
Related Models
Maytag LAT9706AAE WASHER-TOP LOADING
Maytag LAT9706AAM WASHER-TOP LOADING
Maytag LAT9706AAQ WASHER-TOP LOADING
Maytag LAT9706ABE WASHER-TOP LOADING
Maytag LAT9714AAE WASHER-TOP LOADING
Maytag LAT9714AAL WASHER-TOP LOADING
Maytag LAT9714AAM WASHER-TOP LOADING
Maytag LAT9734AAE WASHER-TOP LOADING
Maytag LAT9734AAL WASHER-TOP LOADING
Maytag LAT9734AAM WASHER-TOP LOADING
Maytag LAT9734ABE WASHER-TOP LOADING
Maytag LAT9757AAE WASHER-TOP LOADING
Maytag LAT9757AAM WASHER-TOP LOADING
Maytag LAT9766AAE WASHER-TOP LOADING
Maytag LAT9800AAL WASHER-TOP LOADING
Maytag LAT9800AAW WASHER-TOP LOADING
Maytag LAT9800ABL WASHER-TOP LOADING
Maytag LAT9800ABW WASHER-TOP LOADING
Maytag LAT9800AGL WASHER-TOP LOADING
Maytag LAT9800AGW WASHER-TOP LOADING
Maytag LAT9804AAE WASHER-TOP LOADING
Maytag LAT9804AAL WASHER-TOP LOADING
Maytag LAT9804AAM WASHER-TOP LOADING
Maytag LAT9804ABE WASHER-TOP LOADING
Maytag LAT9806AAE WASHER-TOP LOADING
Maytag LAT9806AAM WASHER-TOP LOADING
Maytag LAT9806ABE WASHER-TOP LOADING
Admiral LAT9806AGE WASHER-TOP LOADING
Admiral LAT9806AKM WASHER-TOP LOADING
Admiral LAT9806AKQ WASHER-TOP LOADING
Admiral LAT9806BGE WASHER-TOP LOADING
Admiral LAT9806DAM WASHER-TOP LOADING
Admiral LAT9806DAQ WASHER-TOP LOADING
Admiral LAT9806GGE WASHER-TOP LOADING
Maytag LAT9824AAE WASHER-TOP LOADING
Maytag LAT9824AAL WASHER-TOP LOADING
Maytag LAT9824AAM WASHER-TOP LOADING
Maytag LAT9824ABE WASHER-TOP LOADING
Maytag LAT9824ABL WASHER-TOP LOADING
Maytag LAT9824ABM WASHER-TOP LOADING
Admiral LAT9824AGE WASHER-TOP LOADING
Admiral LAT9824AKM WASHER-TOP LOADING
Admiral LAT9824BGE WASHER-TOP LOADING
Admiral LAT9824DAM WASHER-TOP LOADING
Admiral LAT9824GGE WASHER-TOP LOADING
Maytag LAT9900AAL WASHER-TOP LOADING
Maytag LAT9900AAW WASHER-TOP LOADING
Maytag LAT9900ABL WASHER-TOP LOADING
Maytag LAT9900ABW WASHER-TOP LOADING
Maytag LAT9904AAE WASHER-TOP LOADING
Maytag LAT9904AAL WASHER-TOP LOADING
Maytag LAT9904AAM WASHER-TOP LOADING
Maytag LAT9904ABE WASHER-TOP LOADING
Admiral LATA100AAE WASHER-TOP LOADING
Admiral LATA100AAL WASHER-TOP LOADING
Admiral LATA100AAM WASHER-TOP LOADING
Admiral LATA100AAW WASHER-TOP LOADING
Admiral LATA100AGE WASHER-TOP LOADING
Admiral LATA100AJE WASHER-TOP LOADING
Admiral LATA100AKE WASHER-TOP LOADING
Admiral LATA100ARE WASHER-TOP LOADING
Admiral LATA200AAE WASHER-TOP LOADING
Admiral LATA200AAL WASHER-TOP LOADING
Admiral LATA200AAM WASHER-TOP LOADING
Admiral LATA200AAW WASHER-TOP LOADING
Admiral LATA200AGE WASHER-TOP LOADING
Admiral LATA200AJE WASHER-TOP LOADING
Admiral LATA200AJM WASHER-TOP LOADING
Admiral LATA300AAE WASHER-TOP LOADING
Admiral LATA300AAL WASHER-TOP LOADING
Admiral LATA300AAM WASHER-TOP LOADING
Admiral LATA300AAW WASHER-TOP LOADING
Admiral LATA300AGL WASHER-TOP LOADING
Admiral LATA300AGW WASHER-TOP LOADING
Admiral LATA400AAE WASHER-TOP LOADING
Admiral LATA400AAL WASHER-TOP LOADING
Admiral LATA400AAM WASHER-TOP LOADING
Admiral LATA400AAW WASHER-TOP LOADING
Admiral LATA400AGE WASHER-TOP LOADING
Admiral LATA400AKE WASHER-TOP LOADING
Admiral LATA400AKL WASHER-TOP LOADING
Admiral LATA400ASE WASHER-TOP LOADING
Admiral LATA401AGE WASHER-TOP LOADING
Admiral LATA401AGM WASHER-TOP LOADING
Admiral LATA401AKE WASHER-TOP LOADING
Admiral LATA401ARE WASHER-TOP LOADING
Admiral LATA500AAE WASHER-TOP LOADING
Admiral LATA500AAL WASHER-TOP LOADING
Admiral LATA500AAW WASHER-TOP LOADING
Hoover LATH100AAM WASHER-TOP LOADING
Hoover LATH100AAV WASHER-TOP LOADING
Hoover LATH100AKM WASHER-TOP LOADING
Hoover LATH100AKV WASHER-TOP LOADING
Hoover LATH100ARV WASHER-TOP LOADING
Hoover LATH100ARW WASHER-TOP LOADING
Hoover LATH100ATV WASHER-TOP LOADING
Hoover LATH300AAV WASHER-TOP LOADING
Hoover LATH300AKM WASHER-TOP LOADING
Hoover LATH300AKV WASHER-TOP LOADING
Hoover LATH300ARV WASHER-TOP LOADING
Hoover LATH300ATV WASHER-TOP LOADING
Hoover LATH400AAV WASHER-TOP LOADING
Hoover LATH400ATV WASHER-TOP LOADING
 LAU091CNP Air Conditioner
 LAU091HNP Air Conditioner
 LAU095HV Air Conditioner
 LAU121HNM Air Conditioner
 LAU121HNP Air Conditioner
 LAU125HV Air Conditioner
 LAU181CNW Air Conditioner
 LAU185HV Air Conditioner
 LAU245HV Air Conditioner
Maytag LAV3600AWW WASHER-TOP LOADING
Maytag LAW2400AAE WASHER-TOP LOADING
Maytag LAW2401AAE WASHER-TOP LOADING
Maytag LAW7500AAL WASHER-TOP LOADING
Maytag LAW7500AAW WASHER-TOP LOADING
Maytag LAW7500ABL WASHER-TOP LOADING
Maytag LAW7500ABW WASHER-TOP LOADING
Maytag LAW7500ABX WASHER-TOP LOADING
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Hot Point Bearing Replacement Hopefulnow Dryer Repair 2 02-08-2010 01:08 PM
Rear Bearing replacement Randy Adams Dryer Repair 1 09-11-2009 01:40 PM
top bearing replacement marcle Dryer Repair 1 08-01-2009 02:04 PM
Bearing Replacement Tom F Washer Repair 1 05-05-2009 03:22 PM
T bearing replacement Corey P Washer Repair 7 04-30-2009 10:14 AM
