Discuss
Maytag Atlantic- Only get Hot Water
 in
Washer Repair
The Hot/Cold switch is the only one that works and it will only fill the wash with hot water. When
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Atlantic- Only get Hot Water
  #1 (permalink)
Old 08-14-2011, 09:06 AM
Junior Member
Randy10 is on a distinguished road
Default Maytag Atlantic- Only get Hot Water
Model Number: MAV7258AWW   Brand: Maytag   Age: 5 - 10 years
The Hot/Cold switch is the only one that works and it will only fill the wash with hot water. When it is time for rinse cycle no water is dispensed. Tried this with ATC on and off. Switched connectors on the water fill and cold water fill does work. Was told it is probably temp selector but, would like to know how to verify if that is the problem. Could it be the temp control board or the thermistor?
Related Models
Maytag MAV7258AWW WASHER, ATLANTIS
Maytag MAV7260AWW WASHER, ATLANTIS
Maytag MAV7260BWW WASHER, ATLANTIS
Maytag MAV7357AWQ WASHER, ATLANTIS
Maytag MAV7357AWW WASHER, ATLANTIS
Maytag MAV7358AWQ WASHER, ATLANTIS
Maytag MAV7358AWW WASHER, ATLANTIS
Maytag MAV7450AWQ WASHER, ATLANTIS
Maytag MAV7450AWW WASHER, ATLANTIS
Maytag MAV7501EWW WASHER, ATLANTIS
Maytag MAV7504EWW WASHER, ATLANTIS
Maytag MAV7550AWQ WASHER, ATLANTIS
Maytag MAV7550AWW WASHER, ATLANTIS
Maytag MAV7551AWQ WASHER, ATLANTIS
Maytag MAV7551AWW WASHER, ATLANTIS
Maytag MAV7557EWQ WASHER, ATLANTIS
Maytag MAV7557EWW WASHER, ATLANTIS
Maytag MAV7580EWQ WASHER, ATLANTIS
Maytag MAV7580EWW WASHER, ATLANTIS
Admiral MAV7600ACQ WASHER-TOP LOADING
Admiral MAV7600AGW WASHER-TOP LOADING
Maytag MAV7600AWQ WASHER, ATLANTIS
Maytag MAV7600AWW WASHER, ATLANTIS
Admiral MAV7600BGW WASHER-TOP LOADING
Admiral MAV7600CGW WASHER-TOP LOADING
Maytag MAV7650AWQ WASHER, ATLANTIS
Maytag MAV7650AWW WASHER, ATLANTIS
Maytag MAV7657EWQ WASHER, ATLANTIS
Maytag MAV7657EWW WASHER, ATLANTIS
Maytag MAV7700AWQ WASHER, ATLANTIS
Maytag MAV7700AWW WASHER, ATLANTIS
Admiral MAV7750AGW WASHER-TOP LOADING
Admiral MAV7750BGW WASHER-TOP LOADING
Admiral MAV7750CGW WASHER-TOP LOADING
Maytag MAV7757AWQ WASHER, ATLANTIS
Maytag MAV7757AWW WASHER, ATLANTIS
Maytag MAV8000AWQ WASHER, ATLANTIS
Maytag MAV8000AWW WASHER, ATLANTIS
Maytag MAV8057AWQ WASHER, ATLANTIS
Maytag MAV8057AWW WASHER, ATLANTIS
Maytag MAV8260AWQ WASHER, ATLANTIS
Maytag MAV8260AWW WASHER, ATLANTIS
Maytag MAV8500AWQ WASHER, ATLANTIS
Maytag MAV8500AWW WASHER, ATLANTIS
Maytag MAV8551AWQ WASHER, ATLANTIS
Maytag MAV8551AWW WASHER, ATLANTIS
Maytag MAV8557AWQ WASHER, ATLANTIS
Maytag MAV8557AWW WASHER, ATLANTIS
Maytag MAV8600AWQ WASHER, ATLANTIS
Maytag MAV8600AWW WASHER, ATLANTIS
Maytag MAV8601AWQ WASHER, ATLANTIS
Maytag MAV8601AWW WASHER, ATLANTIS
Maytag MAV8757AWQ WASHER, ATLANTIS
Maytag MAV8757AWW WASHER, ATLANTIS
Maytag MAV9501EWQ WASHER, ATLANTIS
Maytag MAV9501EWW WASHER, ATLANTIS
Maytag MAV9504EWQ WASHER, ATLANTIS
Maytag MAV9504EWW WASHER, ATLANTIS
Maytag MAV9557EWQ WASHER, ATLANTIS
Maytag MAV9557EWW WASHER, ATLANTIS
Maytag MAV9600EWQ WASHER, ATLANTIS
Maytag MAV9600EWW WASHER, ATLANTIS
Maytag MAV9657EWQ WASHER, ATLANTIS
Maytag MAV9657EWW WASHER, ATLANTIS
Maytag MAV9750AGW WASHER, ATLANTIS
Maytag MAV9750AWQ WASHER, ATLANTIS
Maytag MAV9750AWW WASHER, ATLANTIS
Maytag MAVT236AWW WASHER-TOP LOADING
Maytag MAVT346AWW WASHER-TOP LOADING
Maytag MAVT446AWW WASHER-TOP LOADING
Maytag MAVT546EWW WASHER-TOP LOADING
Maytag MAVT634AWW WASHER, ATLANTIS
Maytag MAVT734EWW WASHER, ATLANTIS
Maytag MAVT754EWW WASHER, ATLANTIS
Maytag MAVT834AWQ WASHER, ATLANTIS
Maytag MAVT834AWW WASHER, ATLANTIS
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Thermador MB245 MICROWAVE
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0 Microwaves*
Whirlpool MB7120XYB1 Microwaves*
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ REF - BOTTOM MOUNTS
Maytag MBB1952GRW REF - BOTTOM MOUNTS
Maytag MBB1952HEB REF - BOTTOM MOUNTS
Maytag MBB1952HEB1 REFRIGERATOR
Maytag MBB1952HEB10 REFRIGERATOR
Maytag MBB1952HEQ REF - BOTTOM MOUNTS
Maytag MBB1952HEW REF - BOTTOM MOUNTS
Maytag MBB1952HEW14 REFRIGERATOR
Maytag MBB1952HEW5 REFRIGERATOR
Maytag MBB1953WEB0 REFRIGERATOR
Maytag MBB1953WEB1 REFRIGERATOR
Maytag MBB1953WEB2 REFRIGERATOR
Maytag MBB1953WEW0 REFRIGERATOR
Maytag MBB1953WEW1 REFRIGERATOR
Maytag MBB1953WEW2 REFRIGERATOR
Maytag MBB1953XEB0 REFRIGERATOR
Maytag MBB1953XEW0 REFRIGERATOR
Maytag MBB1954GEB REF - BOTTOM MOUNTS
Maytag MBB1954GEQ REF - BOTTOM MOUNTS
Maytag MBB1954GES REF - BOTTOM MOUNTS
Maytag MBB1954GEW REF - BOTTOM MOUNTS
Maytag MBB1954HEW REF - BOTTOM MOUNTS
Maytag MBB1956GEB REF - BOTTOM MOUNTS
Maytag MBB1956GEQ REF - BOTTOM MOUNTS
Maytag MBB1956GES REF - BOTTOM MOUNTS
Maytag MBB1956GEW REF - BOTTOM MOUNTS
Maytag MBB1956HEB REF - BOTTOM MOUNTS
Maytag MBB1956HEB14 REFRIGERATOR
Maytag MBB1956HEQ REF - BOTTOM MOUNTS
Maytag MBB1956HES REF - BOTTOM MOUNTS
Maytag MBB1956HEW REF - BOTTOM MOUNTS
  #2 (permalink)
Old 08-15-2011, 06:37 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Okay, from your description you are not getting power to the cold water valve.
The temp switch, or the ATC board are the likely suspects, and my experience on these is that it is the ATC board.
__________________
  #3 (permalink)
Old 08-15-2011, 09:01 PM
Junior Member
Default
Here's a little more info, since my post yesterday I found some additional information on your site mentioning the thermistor should ohm between 10k & 100k. I read open when I disconnect both wires and take reading. Control selector seems to ohm out OK. If I have 120v on temp control board between connector #3(blue 37) and #1 common (white 7) would you say fill valve assembly and if I don't have 120v on that cold output it is temp control board? Thanks
  #4 (permalink)
Old 08-16-2011, 06:00 AM
Senior Expert
APP Volunteer
Default
I don't have access to those specs or the wiring diagram for the model, so I can only say you will have to try and replace components and see which one fixes the problem.
Yes, I know that is not very scientific, or even very professional but that's what repair folks do these days when these types of parts are involved.. If you had a service tech out that is what he or she would do.
I will be at the shop today and will try to find out more with some documentation on similar models.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag - no water sbennett971 Dishwasher Repair 3 09-23-2010 11:30 AM
no water in maytag arcbiscuit Washer Repair 3 08-23-2010 08:30 AM
Maytag Atlantic dryer won't start Jeramie50 Dryer Repair 1 08-02-2010 04:28 PM
Maytag has new water valve, but no water ultimatefighter34 Dishwasher Repair 3 11-02-2007 01:02 PM
