washer fills with water but when it tries to agatate it seems like it binds up. i can move the switch to the rinse cycle and it drains the water,then fills again and then when that cycle is over it will spin. ttrouble is in wash cycle. its a fridgidare.
Does the motor run at that time?
The model number you posted does not come up. Verify and repost it.
my agitator is not turning. the coupling is broke. does this mean my gearbox is locked up ? kenmore model 11092595500 Should the agitator move freely with the washer off? The motor works fine.I did fine the coupling destroyed.
Broken coupling is one of most common problems with direct drive washers and, in most cases it does not mean a problem with the gear case. No, the agitator should not move freely. - The part number for the coupling is AP3963893Gene.
