Discuss
Speed Queen/Amana not pumping out
 in
Washer Repair
We have a Speed Queen Ultra Wash HD Washer (extra-large capacity drum) that's about 15 years old. Never
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Speed Queen/Amana not pumping out
  #1 (permalink)
Old 03-29-2009, 11:01 PM
Roj Roj is offline
Junior Member
Roj is on a distinguished road
Default Speed Queen/Amana not pumping out
Model Number: UWM593W-1102   Brand: Speed Queen   Age: More than 10 years
We have a Speed Queen Ultra Wash HD Washer (extra-large capacity drum) that's about 15 years old. Never been an issue with it until now. The motor/pump/belt tensioner assembly is identical to an Amana LWA50AW. Here's the parts diagram:
Replacement parts for AMANA LWA50AW | AppliancePartsPros.com
The first thing that happened with it was that it was in the middle of a large load and it wouldn't pump the water out after the wash. It would try and then there would be a loud clunk and it would stop. We tried rebalancing the load a couple times with no change of results so we took the machine apart so we could have a look inside to see what's wrong with it. When I got inside it I couldn't see anything that was out of the ordinary. If I pulled on the drive belt everything rotated easily, The brake released, the agitator spun the motor and pump moved smoothly and easily. I noticed the belt looked old and needed replacement so I went to a place that sold belts for electric motors and got a replacement belt. The only problem was that the belt for my machine is supposed to be 32.5" and all I could get was a 32" or a 33" so I took the 32".
I've installed it and because it's a little shorter I was unable to have the tensioner pulley on the outside of the belt where it's supposed to be so I basically eliminated the tensioner altogether. It seems fine that way with the shorter belt. The belt is reasonably tight around both pulleys but not overly tight so as to put a lot of stress on the motor or agitator bearings.
The machine now seems to run fine through the wash cycle. When it comes time to pump the water out ahead of the rinse cycle it starts spooling up the revs for about 3-4 seconds and then you hear a click and the motor shuts off. Sometimes it even blows a breaker. A few minutes later it comes back on and tries to spool up for pumping the water out 3-4 seconds in it cuts out again. I felt the motor after several several failed attempts and the motor was quite hot.
If take out the clothes and bail out the water to where there's only a few inches at the bottom I can get it to spool up and pump all the water out. If I then put in the wet clothes I can get it to spin them for a whole spin cycle. That tells me the pump is fine so I'm thinking the motor has lost some of it's mojo and is having problems operating under heavy load when there's a full load of water and clothes in there. I'm thinking maybe it needs new brushes or something. Am I on the right track here ?
Could this problem have anything to do with the way I've got the belt setup now ? I'm thinking likely not because the belt is snug but still loose enough you can pinch it in a quarter inch or so and when I pull the belt everything including the motor turns easily so I don't think the belt tension is putting too much load on the bearings, etc.
Any advise/insights here would be much appreciated. I don't want to go getting a new motor or having the existing one overhauled if I don't have to.
Thanks.
Related Models
Maytag UXA1000AAB Misc / Accessory
Maytag UXA1000AAP Misc / Accessory
Maytag UXA1000AAQ Misc / Accessory
Maytag UXA1000AAW Misc / Accessory
Maytag UXA1027ADB Misc / Accessory
Maytag UXA1027ADQ Misc / Accessory
Maytag UXA1027ADW Misc / Accessory
Maytag UXA1030ADB Misc / Accessory
Maytag UXA1030ADQ Misc / Accessory
Maytag UXA1030ADW Misc / Accessory
Jenn-Air UXA9007AAB Misc / Accessory
Jenn-Air UXA9007AAQ Misc / Accessory
Jenn-Air UXA9007AAW Misc / Accessory
Maytag UXT2030AAB Hood
Maytag UXT2030AAQ Hood
Maytag UXT2030AAS Hood
Maytag UXT2030AAW Hood
Maytag UXT2036AAB Hood
Maytag UXT2036AAQ Hood
Maytag UXT2036AAS Hood
Maytag UXT2036AAW Hood
Maytag UXT3030AAB Hood
Maytag UXT3030AAQ Hood
Maytag UXT3030AAS Hood
Maytag UXT3030AAW Hood
Maytag UXT3036AAB Hood
Maytag UXT3036AAQ Hood
Maytag UXT3036AAS Hood
Maytag UXT3036AAW Hood
Maytag UXT4030AAB Hood
Maytag UXT4030AAQ Hood
Maytag UXT4030AAS Hood
Maytag UXT4030AAW Hood
Maytag UXT4036AAB Hood
Maytag UXT4036AAQ Hood
Maytag UXT4036AAS Hood
Maytag UXT4036AAW Hood
Maytag UXT5230ADB Hood
Maytag UXT5230ADQ Hood
Maytag UXT5230ADS Hood
Maytag UXT5230ADW Hood
Maytag UXT5236ADB Hood
Maytag UXT5236ADQ Hood
Maytag UXT5236ADS Hood
Maytag UXT5236ADW Hood
Maytag UXT5430ADB Hood
Maytag UXT5430ADQ Hood
Maytag UXT5430ADS Hood
Maytag UXT5430ADW Hood
Maytag UXT5436ADB Hood
Maytag UXT5436ADQ Hood
Maytag UXT5436ADS Hood
Maytag UXT5436ADW Hood
Thermador V-206
Thermador V-207
Thermador V-6
Thermador V-QT-200
Thermador V-QT-300
Thermador V-QT-400
Thermador V-QT-90
Whirlpool V125
Whirlpool V135
Frigidaire V13A Frg(v1) / Upright Freezer
Frigidaire V13B Frg(v2) / Upright Freezer
Whirlpool V140
Whirlpool V150
Frigidaire V16A Frg(v1) / Upright Freezer
Frigidaire V16B Frg(v2) / Upright Freezer
Frigidaire V16C Frg(v3) / Upright Freezer
Frigidaire V21A Frg(v1) / Upright Freezer
Frigidaire V21B Frg(v2) / Upright Freezer
Frigidaire V21C Frg(v3) / Upright Freezer
Amana VA2013 Washer - Top Loading
Amana VA4013 Washer - Top Loading
Amana VA6013 Washer - Top Loading
General Electric VBSR1070T2AB Washer
General Electric VBSR1070T2WB Washer
General Electric VBSR1070T3AB Washer
General Electric VBSR1070T3WB Washer
General Electric VBSR1070T4AB Washer
General Electric VBSR1070T4WB Washer
General Electric VBSR1070T5AB Washer
General Electric VBSR1070T5WB Washer
General Electric VBSR1070T5WW Washer
General Electric VBSR1070T8WW Washer
General Electric VBSR1070TAWW Washer
General Electric VBSR2060V1AA Washer
General Electric VBSR2060V1WW Washer
General Electric VBSR2080W0AA Washer
General Electric VBSR2080W0WW Washer
General Electric VBSR2080W1AA Washer
General Electric VBSR2080W1WW Washer
General Electric VBSR3100B0WW Washer
General Electric VBSR3100B2WW Washer
General Electric VBSR3100B3WW Washer
General Electric VBSR3100D0WW Washer
General Electric VBSR3100D5WW Washer
General Electric VBSR3100DAWW Washer
General Electric VBSR3100DBWW Washer
General Electric VBSR3100DCWW Washer
General Electric VBSR3100G0WW Washer
General Electric VBXR106072WB Refrigerator
General Electric VBXR1060T2AB Washer
General Electric VBXR1060T2WB Washer
General Electric VBXR1060T3AB Washer
General Electric VBXR1060T3WB Washer
General Electric VBXR1060T4AB Washer
General Electric VBXR1060T4WB Washer
General Electric VBXR1060T5AB Washer
General Electric VBXR1060T5WB Washer
General Electric VBXR1060T8AB Washer
General Electric VBXR1060T8WB Washer
General Electric VBXR1060TAAB Washer
General Electric VBXR1060TAWB Washer
General Electric VBXR1060V0AA Washer
General Electric VBXR1060V0WW Washer
General Electric VBXR1060V1AA Washer
General Electric VBXR1060V1WW Washer
General Electric VBXR1070W0AA Washer
General Electric VBXR1070W0WW Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Speed Queen dryer thomk44 Dryer Repair 1 03-10-2009 07:10 PM
Speed Queen-balancing luvs2lauff Washer Repair 0 12-10-2008 07:36 AM
Speed Queen Washer kovall Washer Repair 6 11-13-2008 05:28 PM
Speed Queen Douglas Ressler Washer Repair 1 11-02-2008 07:07 PM
speed queen washer dick2256@hotmail.com Washer Repair 1 03-26-2008 05:12 PM
