Discuss
Washer drains but won't spin or agitate
 in
Washer Repair
Hey everyone, this is my first post. I have a whirlpool top loading washer machine model# LST233DQ0 and it no
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer drains but won't spin or agitate
  #1 (permalink)
Old 08-09-2011, 06:14 PM
Junior Member
Geo2199 is on a distinguished road
Exclamation Washer drains but won't spin or agitate
Model Number: LST7233DQ0   Brand: Whirlpool   Age: 1 - 5 years
Hey everyone, this is my first post. I have a whirlpool top loading washer machine model# LST233DQ0 and it no longer spins or agitates. It still fills and drains fine. I took it out and tipped it over to look at it and it had a pile of black chewed up rubber under it. In between the motor and the bottom of the agitator is something that spins with rubber around it and the rubber piece is now broke in half and its difficult to spin.
Is that the belt or clutch?
and if its the belt is that only thing I have to replace or is there more damage that has occured?
Ads By Google
Related Models
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
Whirlpool LST9355AN0
Whirlpool LST9355AW0
Whirlpool LST9355BN0
Whirlpool LST9355BQ0
Whirlpool LST9355BQ1
Whirlpool LST9355BW0
Whirlpool LST9355BZ0
Whirlpool LST9355BZ1
Whirlpool LST9355DQ0
Whirlpool LST9355DZ0
Whirlpool LSV5132AG0
Whirlpool LSV5132AN0
Whirlpool LSV5132AW0
Whirlpool LSV6233AG0
Whirlpool LSV6233AN0
Whirlpool LSV6233AW0
Whirlpool LSV6234AN0
Whirlpool LSV6234AW0
Whirlpool LSV7233BG0
Whirlpool LSV7233BN0
Whirlpool LSV7233BQ0
Whirlpool LSV7233BW0
Whirlpool LSV7233DQ0
Whirlpool LSV7233DZ0
Whirlpool LSV7244AN0
Whirlpool LSV7244AQ0
Whirlpool LSV7244AW0
Whirlpool LSV7245AN0
Whirlpool LSV7245AQ0
Whirlpool LSV7245AW0
Whirlpool LSV8244BN0
Whirlpool LSV8244BQ0
Whirlpool LSV8244BW0
Whirlpool LSV8244DQ0
Whirlpool LSV8244DZ0
Whirlpool LSV8245AN0
Whirlpool LSV8245AW0
Whirlpool LSV9244DQ0
Whirlpool LSV9244DZ0
Whirlpool LSV9245BN0
Whirlpool LSV9245BW0
Whirlpool LSV9355AN0
Whirlpool LSV9355AW0
Whirlpool LSV9355BN0
Whirlpool LSV9355BW0
Maytag LSW24A Ref - SXS/I&W
Whirlpool LSW9245EQ0
Whirlpool LSW9245EQ1
Whirlpool LSW9245EQ2
Whirlpool LSW9700PQ0 Automatic Washer
Whirlpool LSW9700PQ1 Automatic Washer
Whirlpool LSW9700PQ2 Automatic Washer
Whirlpool LSW9750PW0 Automatic Washer
Whirlpool LSW9750PW1 Automatic Washer
Whirlpool LSW9750PW2 Automatic Washer
Whirlpool LSW9750PW3 Automatic Washer
Frigidaire LT150EXD2 Wwh(v1) / Tumble Action Washer
Frigidaire LT150EXF2 Wwh(v2) / Tumble Action Washer
Frigidaire LT150EXH2 Wwh(v3) / Tumble Action Washer
Frigidaire LT150EXV2 Wwh(v4) / Tumble Action Washer
Frigidaire LT150EXW2 Wwh(v5) / Tumble Action Washer
Frigidaire LT150JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT150JXF1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150JXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150JXV1 Wwh(v4) / Tumble Action Washer
Frigidaire LT150JXW1 Wwh(v5) / Tumble Action Washer
Frigidaire LT150LXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT150LXH1 Wwh(v3) / Tumble Action Washer
Frigidaire LT150LXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXD1 Wwh(v2) / Tumble Action Washer
Frigidaire LT200PXD2 Wwh(v2) / 27 " Front Load Washer
Frigidaire LT200PXW1 Wwh(v1) / Tumble Action Washer
Frigidaire LT200PXW2 Wwh(v1) / 27 " Front Load Washer
Frigidaire LT250EXD2 Wwh(v6) / Tumble Action Washer
Frigidaire LT250EXD4 Wwh(v7) / Tumble Action Washer
Frigidaire LT250EXF2 Wwh(v8) / Tumble Action Washer
Frigidaire LT250EXF4 Wwh(v9) / Tumble Action Washer
Frigidaire LT250EXH2 Wwh(v10) / Tumble Action Washer
Frigidaire LT250EXH4 Wwh(v11) / Tumble Action Washer
Frigidaire LT250EXV2 Wwh(v12) / Tumble Action Washer
Frigidaire LT250EXV4 Wwh(v13) / Tumble Action Washer
Frigidaire LT250EXW2 Wwh(v14) / Tumble Action Washer
Frigidaire LT250EXW4 Wwh(v15) / Tumble Action Washer
  #2 (permalink)
Old 08-09-2011, 06:44 PM
Junior Member
Default
I looked at a video online and its the part in between the motor and transmission. I am pretty sure its a direct drive system with a rubber coupling. The reason I say this is because on both sides of the rubber piece there are two white plastic pieces with 3 tips on them, 1 on the motor and 1 on the transmission on both sides of the rubber piece that is broken. The two white pieces no longer lined up and don't spin together. So all I have to do is replace the rubber coupling? and if the rubber coupling broke is there something else that can be causing this that I should replace also?
  #3 (permalink)
Old 08-12-2011, 08:41 AM
Member
dnlow is on a distinguished road
Default
Yes seems like the motor coupler is your problem. The part is about $15, give or take where you buy it. It will come with both white pieces and the rubber piece. The rubber piece could be all that is bad, you will not know until you have everything apart, but I would replace all three parts since the newer version comes with reinforced plastic pieces. I am thinking that one of the plastic pieces is broken also. This is a fairly easy fix so you should have no problems.
  #4 (permalink)
Old 08-12-2011, 10:32 AM
Junior Member
Default
Quote:
I purchased an upgraded version with a metal piece instead of the rubber one. Its from Whirpool so I'm guessing there aware of the rubber piece failing.
  #5 (permalink)
Old 08-12-2011, 02:26 PM
Junior Member
Default
I installed the new part and now the engine and transmission sits about a half inch to far apart. The old part installed sits all the way down on both the engine and transmission shaft but the new one doesn't. Upon looking at the new plastic part it has a little ridge on two sides of the metal inside preventing it from going all the way down. I tried swapping the plastic pieces on opposite sides and they are still doing the same thing. I tapped it to get it down with my socket and rubber mallet but I didn't wanna hit it to hard and break it.
Should I beat on it to get it down?
I have it installed and the washer machine spins perfectly fine, no weird noises or strange smells. But when you open the door or press the stop button the engine and transmission stop instantly and very violently when it used to spin freely and come to a gentle stop. It stops so hard now the whole washer machine jumps to the right about 2-3ft. I know this is not normal.
And should I be able to turn the motor and transmission freely by hand? Because I could with the old part but not with the new one.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will not spin or agitate, but drains coaner Washer Repair 5 06-03-2011 03:58 PM
washer wont agitate or spin, drains water fine torque1 Washer Repair 0 11-09-2010 06:11 PM
Amana washer won't spin or agitate but drains pixiespage Washer Repair 1 07-25-2010 02:34 PM
GE washer -fills & Drains, but will not spin or agitate tmacky34 Washer Repair 0 03-20-2010 05:54 AM
GE Washer fills/drains but won't spin/agitate sierrapup Washer Repair 1 03-07-2010 08:26 PM
