Discuss
Kenmore (Whirlpool) washer "bang" noise when spinning
 in
Washer Repair
Before I consider disassembling my Kenmore (Whirlpool) washer, I thought I would ask anyone in this forum what the problem
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore (Whirlpool) washer "bang" noise when spinning
  #1 (permalink)
Old 11-24-2007, 11:01 AM
dadasmatta dadasmatta is offline
Junior Member
dadasmatta is on a distinguished road
Default Kenmore (Whirlpool) washer "bang" noise when spinning
Model Number: 110.82891110   Brand: Kenmore   Age: More than 10 years
Before I consider disassembling my Kenmore (Whirlpool) washer, I thought I would ask anyone in this forum what the problem may be with my washer.
The washer works 100% fine up to the spin cycle. About 1/2 through the 1st spin cycle, the machine lets out an instant "bang" noise once it has reached maximum spin speed. The lower spinning agitator seems to quickly stop and then will spin-up again. The machine will "bang" again once it has again reached maximum spin speed. I have to shut down the washer at this point because I don't want to risk further damage to the machine.
I checked the plastic splining on the lower agitator and the metal splining on the drive shaft. Both seem ok.
Is there a possible problem with the gearbox? Bad gears? How can I verify?
I don't suspect the motor/transmission coupler is bad because the machine will spin.
Is it possible the clutch is slipping and re-engaging during the fastest rpm speed of the agitator/basket causing this loud "bang" noise?
If the clutch is suspect, how can a defective clutch be easily verified? How difficult is it to replace the clutch?
Lastly, can someone direct me to a thread or website that best describes the removal process for the clutch or transmission should I need to remover either.
Any comments would be greatly appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-22-2007, 02:30 PM
dbc dbc is offline
Junior Member
dbc is on a distinguished road
Default bang noise when spinning
Did yoy get a reply for this problem? I have the same issue
  #3 (permalink)
Old 12-22-2007, 08:34 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull the outer cover from the washer and remove pump and motor. Turn the coupler clockwise till the spin basket starts to turn. If it turns really hard, either you have something jamming the basket between the tub and basket or you have jamming brake shoes. If it turns really easy, but you get a clunk in the tranny, you have a stripped nylon gear in the tranny=new tranny time. Please post results, I'm betting on a bad tranny. They do sell a spin gear and pinion gear for the tranny if you need it. To confirm, you need to pull tranny and check.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Older Kenmore washer appears "dead"! Cappy Washer Repair 0 10-27-2007 08:18 PM
Starts cycle, gets "stuck" with h2o in bottom, timer is still heard-lights on too. julialovesjohn Dishwasher Repair 1 10-03-2007 08:16 PM
Only freezes in "quick freeze" mode alraybonsue Refrigerator & Freezer Repair 0 09-23-2007 08:10 PM
Dispencer "flap" sticking open mommom02 Refrigerator & Freezer Repair 0 08-31-2007 12:02 PM
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
