Discuss
I hate my washer.
 in
Washer Repair
Not the first time I've had to take it apart. Not the washers fault, really. There was a dime
Appliance Repair Forum > Appliance Repair Help > Washer Repair » I hate my washer.
  #1 (permalink)
Old 03-29-2009, 01:06 PM
paddling_man paddling_man is offline
Junior Member
paddling_man is on a distinguished road
Default I hate my washer.
Model Number: 25062 (Whirlpool) Top Loading Calypso   Brand: Kenmore   Age: 1 - 5 years
Not the first time I've had to take it apart. Not the washers fault, really. There was a dime in the outflow tube.
Still, this time was a bit different. I was seeing a variety of faults: CE (communication error) SR (stuck relay) LD (long discharge) and... heck, there was something else, I'm sure.
Either way, I took everything apart and found TWO underwires from one of my wife's bras (34D. )
Both were individually blocking the float balls. I've got them both out and when the washers cycles, it pauses at the 13 minute mark for express wash. Rinse but prior to spin. It finally give an OB (off balance) error and shuts down.
This happens with some clean-up towels in the wash or even empty.
Any ideas? Thanks in advance!
Related Models
Jenn-Air 2513 Surface Unit - Ele
Jenn-Air 2513N
Jenn-Air 2513S
Jenn-Air 2514 Surface Unit - Ele
Jenn-Air 2514A Surface Unit - Ele
Jenn-Air 2514B Surface Unit - Ele
Jenn-Air 2514N
Jenn-Air 2514S
Jenn-Air 2515 Surface Unit - Ele
Whirlpool 2521B00
Whirlpool 2521B10
Whirlpool 2521B20
Whirlpool 2521B30
Whirlpool 2521B40
Whirlpool 2521B50
Whirlpool 2521B60
Whirlpool 2521W00
Whirlpool 2521W30
Whirlpool 2521^30
Kenmore 253.10301000  CHEST FREEZER
Kenmore 253.10301001  CHEST FREEZER
Kenmore 253.10311000  CHEST FREEZER
Kenmore 253.10311001  CHEST FREEZER
Kenmore 253.10311002  FREEZER
Kenmore 253.10911990  FREEZER
Kenmore 253.10911991  CHEST FREEZER
Kenmore 253.10911992  CHEST FREEZER
Kenmore 253.11301100  FREEZER
Kenmore 253.11301101  FREEZER
Kenmore 253.11311100  CHEST FREEZER
Kenmore 253.11312100  FREEZER
Kenmore 253.11312101  FREEZER
Kenmore 253.11312102  SEARS/FREEZER
Kenmore 253.11321100  CHEST FREEZER
Kenmore 253.11321101  FREEZER
Kenmore 253.11351100  FREEZER
Kenmore 253.11351101  CHEST FREEZER
Kenmore 253.11351102  FREEZER
Kenmore 253.11511100  CHEST FREEZER
Kenmore 253.11511101  FREEZER
Kenmore 253.11521100  FREEZER
Kenmore 253.11521102  CHEST FREEZER
Kenmore 253.11521103  FREEZER
Kenmore 253.11531100  FREEZER
Kenmore 253.11531101  FREEZER
Kenmore 253.11531102  FREEZER
Kenmore 253.11531103  FREEZER
Kenmore 253.11541100  CHEST FREEZER
Kenmore 253.11541102  FREEZER
Kenmore 253.11711100  FREEZER
Kenmore 253.11711101  CHEST FREEZER
Kenmore 253.11711102  FREEZER
Kenmore 253.11821100  FREEZER
Kenmore 253.11821101  FREEZER
Kenmore 253.11911100  FREEZER
Kenmore 253.11911101  FREEZER
Kenmore 253.12021100  FREEZER
Kenmore 253.20211000  UPRIGHT FREEZER
Kenmore 253.20211001  FREEZER
Kenmore 253.20211002  UPRIGHT FREEZER
Kenmore 253.20402000  UPRIGHT FREEZER
Kenmore 253.20402002  FREEZER
Kenmore 253.20402003  UPRIGHT FREEZER
Kenmore 253.20911000  CHEST FREEZER
Kenmore 253.20911001  UPRIGHT FREEZER
Kenmore 253.20911002  UPRIGHT FREEZER
Kenmore 253.21021100  FREEZER
Kenmore 253.21021101  FREEZER
Kenmore 253.21021102  FREEZER
Kenmore 253.21021103  FREEZER
Kenmore 253.21021105  FREEZER
Kenmore 253.21041100  FREEZER
Kenmore 253.21041101  FREEZER
Kenmore 253.21041102  FREEZER
Kenmore 253.21041103  FREEZER
Kenmore 253.21041104  FREEZER
Kenmore 253.21041105  FREEZER
Kenmore 253.21041107  FREEZER
Kenmore 253.21041108  FREEZER
Kenmore 253.21082100  FREEZER
Kenmore 253.21082101  FREEZER
Kenmore 253.21082102  FREEZER
Kenmore 253.21082103  FREEZER
Kenmore 253.21082104  FREEZER
Kenmore 253.21082106  FREEZER
Kenmore 253.21082107  FREEZER
Kenmore 253.21101100  FREEZER
Kenmore 253.21111100  UPRIGHT FREEZER
Kenmore 253.21111101  UPRIGHT FREEZER
Kenmore 253.21111102  FREEZER
Kenmore 253.21111103  FREEZER
Kenmore 253.31420100  TOP-MOUNT REFRIGERATOR
Kenmore 253.31420101  TOP-MOUNT REFRIGERATOR
Kenmore 253.31420102  SEARS/REFRIGERATOR
Kenmore 253.31420103  SEARS/REFRIGERATOR
Kenmore 253.31422100  TOP-MOUNT REFRIGERATOR
Kenmore 253.31422101  TOP-MOUNT REFRIGERATOR
Kenmore 253.31422102  SEARS/REFRIGERATOR
Kenmore 253.31422103  SEARS/REFRIGERATOR
Kenmore 253.31424100  TOP-MOUNT REFRIGERATOR
Kenmore 253.31424101  TOP-MOUNT REFRIGERATOR
Kenmore 253.31424102  SEARS/REFRIGERATOR
Kenmore 253.31424103  SEARS/REFRIGERATOR
Kenmore 253.31427100  TOP-MOUNT REFRIGERATOR
Kenmore 253.31427101  TOP-MOUNT REFRIGERATOR
Kenmore 253.31427102  SEARS/REFRIGERATOR
Kenmore 253.31427103  SEARS/REFRIGERATOR
Kenmore 253.31428100  TOP-MOUNT REFRIGERATOR
Kenmore 253.31428101  TOP-MOUNT REFRIGERATOR
Kenmore 253.31428102  SEARS/REFRIGERATOR
Kenmore 253.31428103  SEARS/REFRIGERATOR
Kenmore 253.31429100  TOP-MOUNT REFRIGERATOR
Kenmore 253.31429101  TOP-MOUNT REFRIGERATOR
Kenmore 253.31429102  SEARS/REFRIGERATOR
Kenmore 253.31429103  SEARS/REFRIGERATOR
Kenmore 253.31430100  TOP MOUNT REFRIGERATOR
Kenmore 253.31430101  TOP-MOUNT REFRIGERATOR
Kenmore 253.31430102  TOP-MOUNT REFRIGERATOR
Kenmore 253.31430103  SEARS/REFRIGERATOR
Kenmore 253.31430104  SEARS/REFRIGERATOR
  #2 (permalink)
Old 03-30-2009, 03:59 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Here is a service manual and the tech sheet
https://secured.whirlpool.com/Servic...LE/8178010.pdf
https://www.servicematters.com/docs/...%208522206.pdf
Unfortunately not much on the Out of Balance error.
You may have something that is not lined up correctly.
Try the diagnostics
I would check the plugs and receptacles on the boards for any sign of corrosion, often a light brown or grey coating.
Also check for proper crimping of the pins into the connectors.
You may want to try cleaning them
Unplug the unit
Clean the connectors and receptacles. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
help how do you speciffically replace washer timer on Maytag washer stupid1 Washer Repair 5 07-04-2009 05:21 PM
is this model number washer a direct drive washer dandjwashington Washer Repair 2 05-01-2009 07:26 PM
Change Washer Lid Switch on Stacked Washer/Dryer scottcomputers Washer Repair 1 05-01-2009 10:16 AM
maytag washer/dyer combo washer no water lindavanzandt Washer Repair 0 11-30-2008 08:35 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
