Discuss
Cabrio Washer Showing F1 Code
 in
Washer Repair
After starting a load to wash, the unit will shut down and show F1 on the display. By pressing the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Cabrio Washer Showing F1 Code
  #1 (permalink)
Old 08-09-2011, 09:00 AM
Junior Member
gsmith is on a distinguished road
Default Cabrio Washer Showing F1 Code
Model Number: WHP WTW 6600SW   Brand: Whirlpool   Age: 1 - 5 years
After starting a load to wash, the unit will shut down and show F1 on the display. By pressing the cancel/pause button and then the start button it will start again and continue the run but will stop at various points along the cycle which will require pressing the cancel/pause button and the start button each time it stops to eventually get it through the complete cycle.
Before buying the an electronic control board or user interface board, I would appreciate your advise and recommendation as to what the cause could be and proper repair procedure.
Glenn
Ads By Google
Related Models
Whirlpool WHP1000SB1 PEDESTAL
Whirlpool WHP1000SK0 PEDESTAL
Whirlpool WHP1000SK1 PEDESTAL
Whirlpool WHP1000SL0 PEDESTAL
Whirlpool WHP1000SL1 PEDESTAL
Whirlpool WHP1000SQ0 PEDESTAL
Whirlpool WHP1000SQ1 PEDESTAL
Whirlpool WHP1000ST0 PEDESTAL
Whirlpool WHP1000ST1 PEDESTAL
Whirlpool WHP1000SU1 PEDESTAL
Whirlpool WHP1500SA0 PEDESTAL
Maytag WHP1500SA1 PEDESTAL
Whirlpool WHP1500SB0 PEDESTAL
Maytag WHP1500SB1 PEDESTAL
Whirlpool WHP1500SC0 PEDESTAL
Maytag WHP1500SC1 PEDESTAL
Whirlpool WHP1500SL0 PEDESTAL
Maytag WHP1500SL1 PEDESTAL
Whirlpool WHP1500SQ0 PEDESTAL
Maytag WHP1500SQ1 PEDESTAL
Whirlpool WHP1500ST0 PEDESTAL
Maytag WHP1500ST1 PEDESTAL
Whirlpool WHP1500SU0 PEDESTAL
Maytag WHP1500SU1 PEDESTAL
Whirlpool WHP32812 30" Electric Range Self Clean Oven
Whirlpool WHP54802 30" Electric Range Self Clean Oven
Whirlpool WHP54803 30" Electric Range Self Clean Oven
Whirlpool WHP83812 30" ELECTRIC RANGE CERAN COOKTOP SELF CLEAN
General Electric WHRE5260E0CC Washer
General Electric WHRE5260E0WW Washer
General Electric WHRE5260E1CC Washer
General Electric WHRE5260E1WW Washer
General Electric WHRE5260E6CC Washer
General Electric WHRE5260E6WW Washer
General Electric WHRE5550H0WW WASHER
General Electric WHRE5550H1WW WASHER
General Electric WHRE5550H2WW WASHER
General Electric WHRE5550K0WW WASHER
General Electric WHRE5550K1WW WASHER
General Electric WHRE5550K2WW WASHER
General Electric WHRE5550K3WW WASHER
General Electric WHSB8000B0CC Washer
General Electric WHSB8000B0WW Washer
General Electric WHSB8000B1CC Washer
General Electric WHSB8000B1WW Washer
General Electric WHSB9000B0CC Washer
General Electric WHSB9000B0WC Washer
General Electric WHSB9000B0WW Washer
General Electric WHSE3100A0WB Washer
General Electric WHSE3100A2WB Washer
General Electric WHSE5240D0CC Washer
General Electric WHSE5240D0WW Washer
General Electric WHSE5240D1CC Washer
General Electric WHSE5240D1WW Washer
General Electric WHSE5240DCCC Washer
General Electric WHSE5240DCWW Washer
General Electric WHSR2070V2WB Washer
General Electric WHSR2070V3WB Washer
General Electric WICB103CV1WC Washer
Frigidaire WIDH3 Frg(v18) / Top Loading Washer
Frigidaire WIDH4 Frg(v3) / Top Load Washer
Frigidaire WIDL3 Frg(v19) / Top Loading Washer
Frigidaire WIDL4 Frg(v2) / Top Load Washer
Frigidaire WIDW3 Frg(v20) / Top Loading Washer
Frigidaire WIDW4 Frg(v1) / Top Load Washer
Frigidaire WILH1 Frg(v2) / 27 " Washer
Frigidaire WILL0 Frg(v2) / 27 " Washer
Frigidaire WILL1 Frg(v3) / 27 " Washer
Frigidaire WILW0 Frg(v1) / 27 " Washer
Frigidaire WILW1 Frg(v1) / 27 " Washer
Frigidaire WIMA1 Frg(v16) / Washer
Frigidaire WIMA2 Frg(v17) / Washer
Frigidaire WIMA3 Frg(v15) / Washer
Frigidaire WIMF1 Frg(v18) / Washer
Frigidaire WIMF2 Frg(v19) / Washer
Frigidaire WIMF3 Frg(v16) / Washer
Frigidaire WIMH1 Frg(v20) / Washer
Frigidaire WIMH2 Frg(v21) / Washer
Frigidaire WIMH3 Frg(v17) / Washer
Frigidaire WIML1 Frg(v22) / Washer
Frigidaire WIML2 Frg(v23) / Washer
Frigidaire WIML3 Frg(v18) / Washer
Frigidaire WIMW1 Frg(v24) / Washer
Frigidaire WIMW2 Frg(v25) / Washer
Frigidaire WIMW3 Frg(v19) / Washer
Frigidaire WISCL2 Frg(v3) / Washer
Frigidaire WISCL3 Frg(v3) / Washer
Frigidaire WISCL5 Frg(v3) / Top Loading Washer
Frigidaire WISCL6 Frg(v4) / Top Load Washer
Frigidaire WISCLL0 Frg(v4) / 27 " Washer
Frigidaire WISCLL1 Frg(v6) / 27 " Washer
Frigidaire WISCLL2 Frg(v2) / 27 " Washer
Frigidaire WISCLW0 Frg(v3) / 27 " Washer
Frigidaire WISCLW1 Frg(v4) / 27 " Washer
Frigidaire WISCLW2 Frg(v1) / 27 " Washer
Frigidaire WISCW2 Frg(v4) / Washer
Frigidaire WISCW3 Frg(v4) / Washer
Frigidaire WISCW5 Frg(v4) / Top Loading Washer
Frigidaire WISCW6 Frg(v3) / Top Load Washer
Frigidaire WISDL2 Frg(v21) / Top Loading Washer
Frigidaire WISDL3 Frg(v5) / Top Load Washer
Frigidaire WISDLL0 Frg(v6) / 27 " Washer
Frigidaire WISDLL1 Frg(v9) / 27 " Washer
Frigidaire WISDLW0 Frg(v5) / 27 " Washer
Frigidaire WISDLW1 Frg(v7) / 27 " Washer
Frigidaire WISDW2 Frg(v22) / Top Loading Washer
Frigidaire WISDW3 Frg(v4) / Top Load Washer
General Electric WISQ416AT5WW Washer
General Electric WISQ416AT6WW Washer
General Electric WISQ416AT7WW Washer
General Electric WISQ416AT8WW Washer
General Electric WISQ416ATAWW Washer
General Electric WISQ416BT5WW Washer
General Electric WISQ416BT6WW Washer
General Electric WISQ416BT7WW Washer
General Electric WISQ416BT8WW Washer
General Electric WISQ416BTAWW Washer
General Electric WISQ416CT5WW Washer
General Electric WISQ416CT6WW Washer
General Electric WISQ416CT7WW Washer
  #2 (permalink)
Old 08-10-2011, 07:03 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
That error code is for a failure of the primary control board.
You will need to replace it to be sure of the diagnosis. If you buy from this site and the board does not fix the problem you can return it, see the returns policy for details and conditions.
__________________
  #3 (permalink)
Old 08-15-2011, 11:07 AM
Junior Member
Default
Thanks for your reply. I contacted Whirlpool and found out this was a recall item and that they sent letters out approximately 2 year ago, which we never received.
You have a great site.
Glenn
  #4 (permalink)
Old 08-15-2011, 12:17 PM
Senior Expert
APP Volunteer
Default
Great, good luck with your machine, hope Whirlpool comes through for you and thanks for the update.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
f1 code on cabrio washer susanv Washer Repair 4 08-09-2011 09:29 AM
fault code for whirlpool cabrio washer tdross Washer Repair 10 07-31-2011 02:27 AM
Whirlpool Cabrio Washer F50 code jiaailun Washer Repair 2 08-13-2010 01:35 PM
F9 Code Showing Frank 1947 Oven Repair (including Ranges and Cooktops) 0 06-28-2010 06:33 PM
ge washer stays in drain w/ imin showing & Code E31 & start/pause blinks sometimes Appliabespecialists Washer Repair 3 02-08-2010 10:14 AM
