| » Maytag Neptune water issue |
Model Number: MAH5500BWW Brand: Maytag Age: 1 - 5 years
I have an issue with water trickling into the washer when I start the cycle, for both hot and cold water. The pressure from the hose when disconnected from the washer is strong. I'm thinking there may be some blockage inside the washer? I'm sure sediment from the water is building up as we use well water, although our water is not "hard". How difficult is it to get inside and inspect this and see if there is blockage somewhere? Any other suggestions would be greatly appreciated. Thanks
Related Models |
Most likely the problem is a bad water inlet valve (#2 on the diagram)
You can find the disassembly instructions in the Service manual. - The part number for the water inlet valve is AP4026884 Here are the break down diagrams and Replacement parts for MAYTAG MAH5500BWW | AppliancePartsPros.com Gene.
__________________
Professional appliance repair in Orange County, California. |
| Display Modes | |
| Maytag water level issue | jonmaytag5537 | Washer Repair | 1 | 11-09-2009 06:35 PM |
| maytag neptune leaks water | oscarwylie | Washer Repair | 6 | 11-01-2009 08:31 AM |
| maytag neptune wont agitate after it take little water | mani | Washer Repair | 2 | 08-28-2009 03:55 PM |
| Maytag Neptune Washer no hot water | harperhomewa | Washer Repair | 1 | 12-21-2008 02:53 PM |
| Maytag Neptune won't extract water completely | letsal | Dishwasher Repair | 3 | 05-19-2008 12:23 PM |
