sometimes the washer won't spin it always drains. if i turn the drum a little and close the lid it will start spinning. it is noisy like a bearing roar. could a sticking bearing cause this?
Check your model number and if it is not correct please post a correction.
Without that I can only say it could be the bearing, but don't know what else to say. The bearing should not stop it from spinning unless it is really, really bad.
Sometimes The Washer Won't Spin. If You Turn The Drum A Little It Will Start Spinning. The Belt Is Tight. I Have Been Told This Models Motor Reverses Direction To Spin. The Tub Bearing Is Noisy But Not Stuck. I'm Thinking It Could Be The Transmission Or Motor Capacitor? Has Anyone Heard Of This Problem? Thanks I HAVE THE RIGHT MODEL NUMBER LISTED BUT WHEN I LOOK FOR PARTS MODEL WJRS2080T8WW LOOKS IDENTICAL
