Discuss
Washer is not mixing cold water
 in
Washer Repair
The cold water for washing/rinsing will work for a few minutes and then shuts off. The hot/warm water works fine
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer is not mixing cold water
  #1 (permalink)
Old 08-08-2011, 07:52 AM
Junior Member
jmarlow is on a distinguished road
Default Washer is not mixing cold water
Model Number: PAV2300   Brand: Maytag   Age: 5 - 10 years
The cold water for washing/rinsing will work for a few minutes and then shuts off. The hot/warm water works fine for either cycles. The water supply and hose was ok. Any suggestions?
Ads By Google
Related Models
Admiral PAV2300AGW WASHER-TOP LOADING
Maytag PAV2300AWA WASHER-TOP LOADING
Maytag PAV2300AWW WASHER-TOP LOADING
Maytag PAV2360AWW WASHER-TOP LOADING
Admiral PAV2755AAW WASHER-TOP LOADING
Maytag PAV3000AWW WASHER-TOP LOADING
Maytag PAV3100AWW WASHER-TOP LOADING
Admiral PAV3200AAW WASHER-TOP LOADING
Admiral PAV3200AGW WASHER-TOP LOADING
Maytag PAV3200AWW WASHER-TOP LOADING
Maytag PAV3240AWW WASHER-TOP LOADING
Maytag PAV3250AWW WASHER-TOP LOADING
Admiral PAV3300AGW WASHER-TOP LOADING
Admiral PAV3300AKW WASHER-TOP LOADING
Maytag PAV3300AWW WASHER-TOP LOADING
Maytag PAV3360AWW WASHER-TOP LOADING
Admiral PAV3855AAW WASHER-TOP LOADING
Maytag PAV4960AWW WASHER-TOP LOADING
Maytag PAV5000AWQ WASHER-TOP LOADING
Maytag PAV5000AWW WASHER-TOP LOADING
Maytag PAV5057AWW WASHER-TOP LOADING
Maytag PAV5058AWW WASHER-TOP LOADING
Maytag PAV5157AWW WASHER-TOP LOADING
Maytag PAV5158AWW WASHER-TOP LOADING
Admiral PAVS234AWW WASHER-TOP LOADING
Admiral PAVS244AWW WASHER-TOP LOADING
Maytag PAVT134AWW WASHER-TOP LOADING
Maytag PAVT144AWW WASHER-TOP LOADING
Maytag PAVT234AWQ WASHER-TOP LOADING
Maytag PAVT234AWW WASHER-TOP LOADING
Maytag PAVT244AWQ WASHER-TOP LOADING
Maytag PAVT244AWW WASHER-TOP LOADING
Maytag PAVT344AWW WASHER-TOP LOADING
Maytag PAVT444AWW WASHER-TOP LOADING
Maytag PAVT454EWW WASHER-TOP LOADING
Maytag PAVT910AWW WASHER-TOP LOADING
Maytag PAVT915AWW WASHER-TOP LOADING
Maytag PAVT920AWW WASHER-TOP LOADING
Thermador PB30YS
General Electric PB750DN1BB ELECTRIC RANGE
General Electric PB750TN1WW ELECTRIC RANGE
General Electric PB900DP1BB ELECTRIC RANGE
General Electric PB900DP2BB ELECTRIC RANGE
General Electric PB900DP3BB ELECTRIC RANGE
General Electric PB900DP4BB ELECTRIC RANGE
General Electric PB900SP1SS ELECTRIC RANGE
General Electric PB900SP2SS ELECTRIC RANGE
General Electric PB900SP3SS ELECTRIC RANGE
General Electric PB900SP4SS ELECTRIC RANGE
General Electric PB900TP1WW ELECTRIC RANGE
General Electric PB900TP2WW ELECTRIC RANGE
General Electric PB900TP3WW ELECTRIC RANGE
General Electric PB900TP4WW ELECTRIC RANGE
General Electric PB909DP1BB ELECTRIC RANGE
General Electric PB909DP2BB ELECTRIC RANGE
General Electric PB909DP3BB ELECTRIC RANGE
General Electric PB909DP4BB ELECTRIC RANGE
General Electric PB909DP5BB ELECTRIC RANGE
General Electric PB909SP1SS ELECTRIC RANGE
General Electric PB909SP2SS ELECTRIC RANGE
General Electric PB909SP3SS ELECTRIC RANGE
General Electric PB909SP4SS ELECTRIC RANGE
General Electric PB909SP5SS ELECTRIC RANGE
General Electric PB909TP1WW ELECTRIC RANGE
General Electric PB909TP2WW ELECTRIC RANGE
General Electric PB909TP3WW ELECTRIC RANGE
General Electric PB909TP4WW ELECTRIC RANGE
General Electric PB909TP5WW ELECTRIC RANGE
General Electric PB909TR1CC ELECTRIC RANGE
General Electric PB909TR2CC ELECTRIC RANGE
General Electric PB910DP1BB ELECTRIC RANGE
General Electric PB910DP2BB ELECTRIC RANGE
General Electric PB910DP3BB ELECTRIC RANGE
General Electric PB910DP4BB ELECTRIC RANGE
General Electric PB910SP1SS ELECTRIC RANGE
General Electric PB910SP2SS ELECTRIC RANGE
General Electric PB910SP3SS ELECTRIC RANGE
General Electric PB910SP4SS ELECTRIC RANGE
General Electric PB910TP1CC ELECTRIC RANGE
General Electric PB910TP1WW ELECTRIC RANGE
General Electric PB910TP2CC ELECTRIC RANGE
General Electric PB910TP2WW ELECTRIC RANGE
General Electric PB910TP3CC ELECTRIC RANGE
General Electric PB910TP3WW ELECTRIC RANGE
General Electric PB910TP4CC ELECTRIC RANGE
General Electric PB910TP4WW ELECTRIC RANGE
General Electric PB920DP1BB ELECTRIC RANGE
General Electric PB920DP2BB ELECTRIC RANGE
General Electric PB920DP3BB ELECTRIC RANGE
General Electric PB920DP4BB ELECTRIC RANGE
General Electric PB920DP5BB ELECTRIC RANGE
General Electric PB920SP1SS ELECTRIC RANGE
General Electric PB920SP2SS ELECTRIC RANGE
General Electric PB920SP3SS ELECTRIC RANGE
General Electric PB920SP4SS ELECTRIC RANGE
General Electric PB920SP5SS ELECTRIC RANGE
General Electric PB920TP1WW ELECTRIC RANGE
General Electric PB920TP2WW ELECTRIC RANGE
General Electric PB920TP3WW ELECTRIC RANGE
General Electric PB920TP4WW ELECTRIC RANGE
General Electric PB920TP5WW ELECTRIC RANGE
General Electric PB969DP1BB ELECTRIC RANGE
General Electric PB969DP2BB ELECTRIC RANGE
General Electric PB969DP3BB ELECTRIC RANGE
General Electric PB969DP4BB ELECTRIC RANGE
General Electric PB969SP1SS ELECTRIC RANGE
General Electric PB969SP2SS ELECTRIC RANGE
General Electric PB969SP3SS ELECTRIC RANGE
General Electric PB969SP4SS ELECTRIC RANGE
General Electric PB970BM1BB ELECTRIC RANGE
General Electric PB970BM2BB ELECTRIC RANGE
General Electric PB970BM3BB ELECTRIC RANGE
General Electric PB970DP1BB ELECTRIC RANGE
General Electric PB970DP2BB ELECTRIC RANGE
General Electric PB970DP3BB ELECTRIC RANGE
General Electric PB970DP4BB ELECTRIC RANGE
General Electric PB970KM1CC ELECTRIC RANGE
General Electric PB970KM2CC ELECTRIC RANGE
General Electric PB970KM3CC ELECTRIC RANGE
General Electric PB970SM1SS ELECTRIC RANGE
  #2 (permalink)
Old 08-09-2011, 06:51 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Switch the plugs on the water valve assembly, putting the cold on the hot and the hot on the cold. Then see what happens
If the hot water does what the cold water was doing then the problem is likely in the wiring or the timer. Otherwise the problem is likely in the valve assembly, which is the most likely.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Washer Not Filling with Cold Water GHG Washer Repair 0 06-26-2011 07:18 PM
No cold water from Washer stuartgto Washer Repair 3 02-14-2011 08:10 AM
GE Washer No Cold Water lmeiners Washer Repair 2 11-20-2010 03:18 PM
Whirlpool Washer banging when mixing water temps lisarvot@comcast.net Washer Repair 1 04-14-2009 02:26 PM
washer won"t run on cold cold water setting jwh4969 Washer Repair 1 12-23-2008 06:41 AM
