Discuss
Maytag bangs in spin cycle
 in
Washer Repair
In the spin cycle, sounds like there's something hitting the outside casing making a repetitive banging sound. W've just had
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag bangs in spin cycle
  #1 (permalink)
Old 03-28-2009, 10:19 AM
Junior Member
JBS1924 is on a distinguished road
Default Maytag bangs in spin cycle
Model Number: LAT9406ABE   Brand: Maytag   Age: More than 10 years
In the spin cycle, sounds like there's something hitting the outside casing making a repetitive banging sound. W've just had the boot seal and the spin bearings replaced and now it's making his noise. Thanks in advance for any suggestions.
Related Models
Maytag LAT9406ABE WASHER-TOP LOADING
Maytag LAT9416AAE WASHER-TOP LOADING
Maytag LAT9416AAM WASHER-TOP LOADING
Maytag LAT9416AAQ WASHER-TOP LOADING
Maytag LAT9420AAE WASHER-TOP LOADING
Maytag LAT9457AAE WASHER-TOP LOADING
Maytag LAT9457AAM WASHER-TOP LOADING
Maytag LAT9457AAQ WASHER-TOP LOADING
Maytag LAT9457BAE WASHER-TOP LOADING
Maytag LAT9520AAE WASHER-TOP LOADING
Maytag LAT9520AAQ WASHER-TOP LOADING
Maytag LAT9557AAE WASHER-TOP LOADING
Maytag LAT9557AAQ WASHER-TOP LOADING
Maytag LAT9593AAL WASHER-TOP LOADING
Maytag LAT9593AAW WASHER-TOP LOADING
Maytag LAT9593ABL WASHER-TOP LOADING
Maytag LAT9593ABW WASHER-TOP LOADING
Maytag LAT9600AAL WASHER-TOP LOADING
Maytag LAT9600AAW WASHER-TOP LOADING
Maytag LAT9600ABL WASHER-TOP LOADING
Maytag LAT9600ABW WASHER-TOP LOADING
Maytag LAT9604AAE WASHER-TOP LOADING
Maytag LAT9604AAL WASHER-TOP LOADING
Maytag LAT9604AAM WASHER-TOP LOADING
Maytag LAT9604ABE WASHER-TOP LOADING
Maytag LAT9605AAE WASHER-TOP LOADING
Maytag LAT9605AAM WASHER-TOP LOADING
Maytag LAT9606AAE WASHER-TOP LOADING
Maytag LAT9606AAM WASHER-TOP LOADING
Maytag LAT9606ABE WASHER-TOP LOADING
Maytag LAT9606ABM WASHER-TOP LOADING
Admiral LAT9606AGE WASHER-TOP LOADING
Admiral LAT9606BGE WASHER-TOP LOADING
Admiral LAT9606GGE WASHER-TOP LOADING
Maytag LAT9614AAE WASHER-TOP LOADING
Maytag LAT9614AAL WASHER-TOP LOADING
Maytag LAT9614AAM WASHER-TOP LOADING
Maytag LAT9615AAE WASHER-TOP LOADING
Maytag LAT9615AAM WASHER-TOP LOADING
Maytag LAT9616AAE WASHER-TOP LOADING
Maytag LAT9616AAM WASHER-TOP LOADING
Maytag LAT9634AAE WASHER-TOP LOADING
Maytag LAT9634AAL WASHER-TOP LOADING
Maytag LAT9634AAM WASHER-TOP LOADING
Maytag LAT9634ABE WASHER-TOP LOADING
Maytag LAT9635AAE WASHER-TOP LOADING
Maytag LAT9635AAM WASHER-TOP LOADING
Maytag LAT9700AAL WASHER-TOP LOADING
Maytag LAT9700AAW WASHER-TOP LOADING
Maytag LAT9700ABL WASHER-TOP LOADING
Maytag LAT9700ABW WASHER-TOP LOADING
Maytag LAT9700DAL WASHER-TOP LOADING
Maytag LAT9700DAW WASHER-TOP LOADING
Maytag LAT9704AAE WASHER-TOP LOADING
Maytag LAT9704AAL WASHER-TOP LOADING
Maytag LAT9704AAM WASHER-TOP LOADING
Maytag LAT9704ABE WASHER-TOP LOADING
Maytag LAT9704ABL WASHER-TOP LOADING
Maytag LAT9704ABM WASHER-TOP LOADING
Admiral LAT9704AGE WASHER-TOP LOADING
Admiral LAT9704BGE WASHER-TOP LOADING
Maytag LAT9704DAL WASHER-TOP LOADING
Maytag LAT9704DAM WASHER-TOP LOADING
Admiral LAT9704GGE WASHER-TOP LOADING
Maytag LAT9706AAE WASHER-TOP LOADING
Maytag LAT9706AAM WASHER-TOP LOADING
Maytag LAT9706AAQ WASHER-TOP LOADING
Maytag LAT9706ABE WASHER-TOP LOADING
Maytag LAT9714AAE WASHER-TOP LOADING
Maytag LAT9714AAL WASHER-TOP LOADING
Maytag LAT9714AAM WASHER-TOP LOADING
Maytag LAT9734AAE WASHER-TOP LOADING
Maytag LAT9734AAL WASHER-TOP LOADING
Maytag LAT9734AAM WASHER-TOP LOADING
Maytag LAT9734ABE WASHER-TOP LOADING
Maytag LAT9757AAE WASHER-TOP LOADING
Maytag LAT9757AAM WASHER-TOP LOADING
Maytag LAT9766AAE WASHER-TOP LOADING
Maytag LAT9800AAL WASHER-TOP LOADING
Maytag LAT9800AAW WASHER-TOP LOADING
Maytag LAT9800ABL WASHER-TOP LOADING
Maytag LAT9800ABW WASHER-TOP LOADING
Maytag LAT9800AGL WASHER-TOP LOADING
Maytag LAT9800AGW WASHER-TOP LOADING
Maytag LAT9804AAE WASHER-TOP LOADING
Maytag LAT9804AAL WASHER-TOP LOADING
Maytag LAT9804AAM WASHER-TOP LOADING
Maytag LAT9804ABE WASHER-TOP LOADING
Maytag LAT9806AAE WASHER-TOP LOADING
Maytag LAT9806AAM WASHER-TOP LOADING
Maytag LAT9806ABE WASHER-TOP LOADING
Admiral LAT9806AGE WASHER-TOP LOADING
Admiral LAT9806AKM WASHER-TOP LOADING
Admiral LAT9806AKQ WASHER-TOP LOADING
Admiral LAT9806BGE WASHER-TOP LOADING
Admiral LAT9806DAM WASHER-TOP LOADING
Admiral LAT9806DAQ WASHER-TOP LOADING
Admiral LAT9806GGE WASHER-TOP LOADING
Maytag LAT9824AAE WASHER-TOP LOADING
Maytag LAT9824AAL WASHER-TOP LOADING
Maytag LAT9824AAM WASHER-TOP LOADING
Maytag LAT9824ABE WASHER-TOP LOADING
Maytag LAT9824ABL WASHER-TOP LOADING
Maytag LAT9824ABM WASHER-TOP LOADING
Admiral LAT9824AGE WASHER-TOP LOADING
Admiral LAT9824AKM WASHER-TOP LOADING
Admiral LAT9824BGE WASHER-TOP LOADING
Admiral LAT9824DAM WASHER-TOP LOADING
Admiral LAT9824GGE WASHER-TOP LOADING
Maytag LAT9900AAL WASHER-TOP LOADING
Maytag LAT9900AAW WASHER-TOP LOADING
Maytag LAT9900ABL WASHER-TOP LOADING
Maytag LAT9900ABW WASHER-TOP LOADING
Maytag LAT9904AAE WASHER-TOP LOADING
Maytag LAT9904AAL WASHER-TOP LOADING
Maytag LAT9904AAM WASHER-TOP LOADING
Maytag LAT9904ABE WASHER-TOP LOADING
Admiral LATA100AAE WASHER-TOP LOADING
Admiral LATA100AAL WASHER-TOP LOADING
Admiral LATA100AAM WASHER-TOP LOADING
  #2 (permalink)
Old 03-28-2009, 01:26 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
The best thing to do is to take the front off, and through it in a spin cycle, and see what it is doing. The way the front comes off is, on the bottom of the front, on the left hand side, and the right hand side, about three inches off the floor, right in the creese of the front, is a phillips head screw, on each side. Remove them both, and then grab the fron panel on each side, half way up, and pull the bottom toward you, and once you are at a 45 degree angle the top of the panel will drop out of the top of the washer. Real easy. When you put it back on, put it back in at the same angle. Check it out, and let me know what you see. Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Washer Bangs during spin cycle. Boeing727 Washer Repair 1 01-31-2010 10:09 AM
whirlpool washer bangs during spin cycle like its out of balance joekelli Washer Repair 2 01-01-2010 07:12 AM
washer bangs and walks in spin cycle lisarvot@comcast.net Washer Repair 1 02-23-2009 02:19 PM
Maytag wash won't spin on regular cycle but will on gentle cycle BlazingSun Washer Repair 0 01-07-2009 08:41 PM
GE washer bangs when in spin cycle Huntinglover Washer Repair 4 12-04-2008 06:10 PM
