Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Intermittent spin problem (http://forum.appliancepartspros.com/washer-repair/278794-intermittent-spin-problem.html)
ncgal 08-07-2011 10:13 AM
First I posted this;
Quote:
"Stopped spinning in the rinse cycle. Discovered it would spin in the wash cycle. After a couple of loads, now not spinning in wash cycle either.
Help please!!
"Just tried again. When it got to the spin cycle, I hear a humming but no spin. I opened the lid and engaged the switch so I could see what was happening....the agitator starts to move but then stops (the move is just a jerk). There is no smell.
Today just ran a load...spin cycle worked in both the wash and rinse cycle. Yesterday I took the front off..... checked the belt which looked fine. Moved it a little. All I did....still did not spin after that. But today fine...so far.
sidfink43 08-08-2011 05:32 PM
It does not seem like there is a mechanical issue with the washer. I am going to suggest you change out the timer and see if that does not fix your problems. Before doing so check all the wiring and the connections, it could be a broken or partly broken wire or a loose connection.
