I'm not exactly sure how old the washer is- I'm just guessing there. It will not spin even when empty but will drain.
If it will agitate, then it is likely the clutch, see the Sticky by Richappy above and check the clutch and brakes.
If it will not agitate, it is likely the coupling.
