my machine does not always do a final spin. If I open the lid and manually retate the drum a bit then start the spin cycle again it usually works. Is there a drive belt on this model that could be worn?
You were right on target with your repair recommendation. I ordered a new clutch assembly and it did the trick. Also, the video you attached turned out to be critical in order for me to make the repair. I had not been able to find a repair manual, and even if I had I still think I would have needed the video.
I have one other minor issue with the washer, the bleach dispenser doesn't work. It backs up with water even if I don't put bleach in it. Is there a solenoid or something that might be broken?
Thanks again.
