Discuss
Frigidaire washer tub spins during agitation
 in
Washer Repair
Our Washer has developed multiple problems. First, while agitating, the tub rotates and causes a whirlpool inside. Second, while in
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire washer tub spins during agitation
  #1 (permalink)
Old 11-23-2007, 02:43 PM
Aaron Wood Aaron Wood is offline
Junior Member
Aaron Wood is on a distinguished road
Question Frigidaire washer tub spins during agitation
Model Number: fws445rfs0   Brand: Frigidaire   Age: 5 - 10 years
Our Washer has developed multiple problems. First, while agitating, the tub rotates and causes a whirlpool inside. Second, while in spin mode, she sounds like a bearing may be out, or that lift-off is imminent. Finally, there is a water leak right at the bottom center of the tub.
Ouch......anyway, advice and a parts list are needed.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-29-2007, 03:07 PM
kanislatrans kanislatrans is offline
Junior Member
kanislatrans is on a distinguished road
Default
it could be the bolt holding the lockplate has broken off.(ap part2106271). I have seen that quite a bit. and the leaking would be from part ap2142342 -seal. most of the time when the lock plate comes loose the spin tub will rock and wear on the seal.
  #3 (permalink)
Old 12-05-2007, 09:36 AM
Junior Member
Default It's the Quest that makes us Human
Hey thanks for the info on my washer.
I am currently investigating the parts and problems you indicated.
Cross those fingers and hope it is not more serious.
Thank you again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana washer spins but does not drain water out fjhead2000 Washer Repair 2 11-24-2007 09:44 AM
no agitation or spinning chartman Washer Repair 0 11-12-2007 08:30 PM
Washer leaks during agitation Chaz Washer Repair 0 11-05-2007 09:38 AM
roper gas dryer spins but no heat relvis Dryer Repair 1 09-19-2007 10:47 PM
Washer motor spins but will not agitate. jimmyr Washer Repair 1 09-19-2007 05:34 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
