Discuss
Washer only fills with hot water, no water during rinse cycle
 in
Washer Repair
My washer is a Fridgidaire stackable with dryer on top. The water comes in for wash but only hot water.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer only fills with hot water, no water during rinse cycle
  #1 (permalink)
Old 08-04-2011, 07:00 AM
Junior Member
rcmedrec1 is on a distinguished road
Default Washer only fills with hot water, no water during rinse cycle
Brand: Frigidaire   Age: 5 - 10 years
My washer is a Fridgidaire stackable with dryer on top. The water comes in for wash but only hot water. There is no water coming in for rinse cycle. Is this a switch problem?
thanks,
rcmedrec1
  #2 (permalink)
Old 08-05-2011, 06:28 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Probably is a valve assembly problem. You can confirm this by plugging the hot water connector on the valve assembly to the cold water connection. If the machine will not fill on hot water setting, the problem is the valve assembly.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My washer fills so slowly with cold water & stops before rinse cycle JennH Washer Repair 6 07-29-2012 10:20 AM
kenmore washer fills for wash,but no water on rinse cycle doitmyself2011 Washer Repair 3 05-02-2011 12:31 PM
Washer fills with hot water after cycle done jwallack Washer Repair 15 07-22-2009 07:55 PM
washer fills with water and spin when cycle is started huan1 Washer Repair 1 04-01-2009 01:31 PM
Washer fills on wash cycle and rinse cycle and won't stop filling! riphinney Washer Repair 15 03-12-2008 05:30 PM
