Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   washer shorts out between aggitate and pump/spin (http://forum.appliancepartspros.com/washer-repair/27699-washer-shorts-out-between-aggitate-pump-spin.html)
waterdogs 03-26-2009 04:56 PM
8 CYCLE makes the lights blink and goes click click click when it goes from aggatate to pump/spin if i stop it and advance the timer it workes great.
Gene 03-27-2009 07:17 PM
Would it drain and spin if you advance the timer? How far should you move it?
ufmq502710 03-27-2009 07:35 PM
Quote:
I would like to know if the motor itself for GE Profile range hood can be fixed. I'm talking about just the motor. The whole assy is too expensive. Any suggestions? M#jv635h1ww s#dg8019642
Thxs
ufmq502710 03-27-2009 07:39 PM
GE motor range hood assy
Need to know if motorf can be fix to avoid buyint the whole assy.
:( :mad:
ufmq502710 03-27-2009 07:41 PM
Quote:
:( :mad:
Please reply, I'm new to this site?????
Need suggestion on how to fix this motor:mad:
Gene 03-27-2009 07:45 PM
No, the motor is not serviceable. It comes as an assembly only.
- The part number for the blower motor assembly is AP3792681
Here are the break down diagrams and Replacement parts for GE JV635H1WW | AppliancePartsPros.com
waterdogs 03-28-2009 05:54 PM
yes it drains and spins fine if I advance the timer. I just have to move it ahead a tad. Thanks
Gene 03-28-2009 06:10 PM
I would suspect the timer. The model number you posted is incorrect. I believe it should be TAWS700EQ1 instead of TAW5700EQ1. Verify and repost it.
